Hey guys
i found a set of te37 18x9.5+12 and i want to put 235f ,265r and im wondering if they can fit?
I dont mind rolling the guards.i thought a lower offset makes the te37 look aggressive.
all help is appreciated.Simo
Edited by grim reaper
https://www.sau.com.au/forums/topic/338930-te37-18x9512-on-r34-gtt/
hay dude.
i have 18x9.5 te37s front and rear on my r34 +15 and i have rolled, flared and pumped guards
i run 245s f and 265s r
fronts still stick out a tiny bit, rears r sweet. (front guards are pulled same a gtr +25 mm and the rears are pulled more than that coz i used to have deep dish 19'sz)
i have 18x9.5 +12 on my gtt
needed camber arms and that was about it... i rolled the guards just beacuse i could didnt really need doing.
you will be alright
i didnt use camber arms coz i want my wheels to sit flat on the floor for better grip
You will need to roll the front and rear guards, this shouldnt be more then $50 a corner by a shop.
You will need to lower the car to fit them, and it would be best to get camber adjustment for the back at least.
But yes do it the jap way, buy the rims, then make the car fit around them, they will look porn.
doesnt having heaps of negative camber on the front just make it steer better not grip better??
google: understeer happens when the front tires have less traction during a cornering situation than the rear tires, thus causing the front end of the vehicle to have less mechanical grip and become unable to follow the trajectory in the corner.
If the tire had zero camber, the inside edge of the contact patch would begin to lift off of the ground, thereby reducing the area of the contact patch. By applying negative camber, this effect is reduced, thereby maximizing the contact patch area.
more neg camber on front = maximizing the contact patch area during a corner
grip better = steer better
heys guys what if i go 18x9front 235 18x9.5 rear 265 but still te37s
but what offset would i need?
my car allready has 9.5 255,40 rear and 9 225,40 front.i dont know wat offset but rear is deepdish
265s on the rear will be pushing it if you don't wanna pull the guards too. I'd personally go 235s all round, or step it up to a 10.5 on the rear for the 265 (what I'm looking at for mine now).
10.5's on the rear of a gt-t? How are you going to make that fit? offset?
just to give yous more info on my car so yous can help me out more
it has bc raceing coilovers it has 17x9 225 front and 17x9.5 255 rear.i dont mind lipping the guards or pulling them out.so is 18x9.5+12 235front 265 rear 0r should i look for 18x9 235 front and 18x9.5 265 rear and larger offset 15 and up.
my rims now.
post-61653-1286265892.jpg[a
ttachment=307585:P051010_17.02.JPG]
I run both a 17 x 9 +20 (track) and 18 x 9.5 +15 (street) 235/40 all round, I lipped my front guards and rolled my rears to add an extra 10mm of clearance.
But I run my car a bit lower than most, so I have natural camber both front 2 deg and rear 1.5ish , but plan on correcting it with arms soon.
    • Remember kids - if you can't afford to buy 2 GTRs......
    • I know people cry at the price of the Getrag 12-14k for a conversion now, but it really is a nice mid point. Not going to get change from 10k on a gearset installed.  $30k++ for sequential.   I know you run the risk of a damaged used one and parts are hard to get but as a street car gearbox its really hard to beat. If you enjoy a more traditional manual, its the choice no question.
    • Time to decide what’s more import, your power level or your budget because you’re going to struggle to keep both
    • Our Southern Highlands Cruise is proudly registered with “R U OK?” Day.  Sometimes the best way to check in on your mates is by getting out for a drive together. Sharing a common passion like cars creates the perfect space to chat, connect, and support each other.  A simple “R U OK?” can make all the difference. Let's enjoy the drive, the company, and look out for one another. PLEASE WEAR YELLOW FOR “R U OK?” DAY Sunday 14th September 2025 9:30AM Meeting Crossroads Homemaker Centre 10:00AM Cruise Departure Via Old Hume Hwy 11:45AM Arrival at Mittagong RSL Club Meet Location: Crossroads Homemaker Centre Final Destination: Mittagong RSL Club *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yep, its been down for a while, as I understand it it will be back soon.
