Hey,
Im in the market for an R34, but i havent driven one yet. I'd rather waste a car dealers time test driving one than a private sellers. So far i havent been able to find one at a yard... Or any import yards for that matter. I know there are a few in coburg and around that area but i cant rember the name, or find them in the yellow pages.
Anyone know of any? I'm trying to find a stock manual, so i know what the base model is... then ill buy something better.
Im in boronia, so i wanna check they have them in stock before driving all over the city looking for one.
cheers y'all
https://www.sau.com.au/forums/topic/339649-car-yards-melbourne-that-have-r34s/
what eva u do dont go to the place on bell street preston jsa or msa whateva it is
i bought my 34 from jap cars in fawkner, i highly recomend him his name is dennis, a few of the sau boys have got there cars from him also.
Hey James. Sorry mate but I think SEI motors have the worst condition cars I have ever seen. They import garbage and fix it up in aus. Do not buy a car from them. They are dodgy f**ks. A lot of people will agree with ne about them.
guess i must of picked the lucky ones, bought a 33 s2 na had it for 2 years not 1 problem, gave it hell. and now this 33, had it for over a year no problems either apart from common stuff coil packs etc
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
