Hi Chris you going well with this build, nice sunroof save. I'm with you over preferring power over noise. Did you see these e-bay guards?
http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...e=STRK:MEWAX:IT
can anyone tell me what the text is in the top corner of this?
R32_GTR_N1_Oil_cooler.pdf
found the part numbers for it
thess are the 9302 P/Ns
21308-RN581 - bracket
21300-05U20 - cooler kit
08110-6161E - bolts (10)
cannot find prices on these at the moment. looks like a phone call on monday to osaka...
Translation
1. "oil cooler installation will interfere with the existing air conditioning condenser". "if you want an air conditioning condensor, use a kit with this number" from this company Kenso phone them...
2. to install this will make air conditioning difficult!
Edited by WHITE gtt
ok:
tonight removed:
rear tailshaft
front tailshaft
engine ancillaries
this is so I can get the box and engine out a bit easier. the top two engine/box bolts are a bitch to get at. I also ground off the rusted wiper gear in the front. all of that went in the bin as its all past its useby date. I'll order new stuff after I get more money to do so. the rear wiper assy - I have a spare motor now - the nut was so rusted on that I had to cut it off as well and in the process destroyed the threads that hold the lot together. the engine will be out hopefully before the weekend. then the glass comes out and I start getting chemical burns from cleaning.
out of curiosity I pulled the head off the RB20. cylinder #5 rusted. cylinder #6 - black as. headgasket let go I figure and took the rest with it. EVERY line on htat head was catcus wit rust and crap. the entire lot is sitting out side ready for the scrap metal guy to pick up. I kept the cam covers and CAS.
next few days I'll yank the rest out now htat I can get to the back two bolts a bit easier.
  • Like 1
spent some time looking at wheel choice. looking at 17x7s in lenso specifically the DC6 in copper/bronze..
I would prefer simmons gold mesh but it looks like they are no longer made :blink: . I feel the lenso wheels would suit a red car - would like to hear feedback on this idea :(
been looking for a set of those. they seem to be made of unobtainium for some reason. those were my first thought until I saw the yahoo japan site.
yeah i bought mine from a guy i know that owns an import wreckers. he gave them to me for $550 with tires. we thought they were just the normal bbs rims until i got home and checked the text around the center caps. had the part number and all on it lol
Knowing you Chris if you think the BBS are best, you'll track them down! I like the Simmons option, I tend to buy second hand and refurbish, the modular construction means you could "tailor them". This interests me for GTS4s.
had simmons P86s (gold mesh) on a previous car. liked them. that was my goal but I cannot buy them anymore.
have found a 'donor' GTR for small bits and pieces local to me. that is going to get a fair bit of stuff taken off it I think. (thanks go to a darling downs member btw.)
02stagea,
ta!
its not the first one I have built though this is the first one that I have went into that much detail though.
talking to another fellow that totally rebuilt a 32 he thought he knew a fair bit about them before he started - he admitted he was wrong. I'm finding the same thing myself. there are that many 'minor' differences in these cars that its entirely NOT funny.
curretnly I'm working from 4 different chassis numbers to get what I want. 3 of them are Vspecs and one Oz GTR.
thanks to a QLD club member I actually worked out the paint on mine and what the car actually *should* look like internally and externally. if I can make it look like THIS as that is my colour I'll be more than happy.
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
