Hi Chris you going well with this build, nice sunroof save. I'm with you over preferring power over noise. Did you see these e-bay guards?
http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...e=STRK:MEWAX:IT
can anyone tell me what the text is in the top corner of this?
R32_GTR_N1_Oil_cooler.pdf
found the part numbers for it
thess are the 9302 P/Ns
21308-RN581 - bracket
21300-05U20 - cooler kit
08110-6161E - bolts (10)
cannot find prices on these at the moment. looks like a phone call on monday to osaka...
Translation
1. "oil cooler installation will interfere with the existing air conditioning condenser". "if you want an air conditioning condensor, use a kit with this number" from this company Kenso phone them...
2. to install this will make air conditioning difficult!
Edited by WHITE gtt
ok:
tonight removed:
rear tailshaft
front tailshaft
engine ancillaries
this is so I can get the box and engine out a bit easier. the top two engine/box bolts are a bitch to get at. I also ground off the rusted wiper gear in the front. all of that went in the bin as its all past its useby date. I'll order new stuff after I get more money to do so. the rear wiper assy - I have a spare motor now - the nut was so rusted on that I had to cut it off as well and in the process destroyed the threads that hold the lot together. the engine will be out hopefully before the weekend. then the glass comes out and I start getting chemical burns from cleaning.
out of curiosity I pulled the head off the RB20. cylinder #5 rusted. cylinder #6 - black as. headgasket let go I figure and took the rest with it. EVERY line on htat head was catcus wit rust and crap. the entire lot is sitting out side ready for the scrap metal guy to pick up. I kept the cam covers and CAS.
next few days I'll yank the rest out now htat I can get to the back two bolts a bit easier.
  • Like 1
spent some time looking at wheel choice. looking at 17x7s in lenso specifically the DC6 in copper/bronze..
I would prefer simmons gold mesh but it looks like they are no longer made :blink: . I feel the lenso wheels would suit a red car - would like to hear feedback on this idea :(
been looking for a set of those. they seem to be made of unobtainium for some reason. those were my first thought until I saw the yahoo japan site.
yeah i bought mine from a guy i know that owns an import wreckers. he gave them to me for $550 with tires. we thought they were just the normal bbs rims until i got home and checked the text around the center caps. had the part number and all on it lol
Knowing you Chris if you think the BBS are best, you'll track them down! I like the Simmons option, I tend to buy second hand and refurbish, the modular construction means you could "tailor them". This interests me for GTS4s.
had simmons P86s (gold mesh) on a previous car. liked them. that was my goal but I cannot buy them anymore.
have found a 'donor' GTR for small bits and pieces local to me. that is going to get a fair bit of stuff taken off it I think. (thanks go to a darling downs member btw.)
02stagea,
ta!
its not the first one I have built though this is the first one that I have went into that much detail though.
talking to another fellow that totally rebuilt a 32 he thought he knew a fair bit about them before he started - he admitted he was wrong. I'm finding the same thing myself. there are that many 'minor' differences in these cars that its entirely NOT funny.
curretnly I'm working from 4 different chassis numbers to get what I want. 3 of them are Vspecs and one Oz GTR.
thanks to a QLD club member I actually worked out the paint on mine and what the car actually *should* look like internally and externally. if I can make it look like THIS as that is my colour I'll be more than happy.
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
