Chris, I can't make out from the pictures but have you sourced those silly ass screws with the housing around them that when screwed down they expand to seal down? They are used along the kick panel that says "skyline" that is only visible when the door is open. If so whats the price tag? Oh and is the brake duct only for 1 side? Cheers
I havent sourced them yet. that said that are a local part as the navara uses them. I'll dig up the part number for them later (its in my book and I have to find it!) . the brake ducts - yep that price is per side.
found something 'interesting' yesterday whilst rebuilding a door harness , the later door boots off a Z11 cube or K12 micra actually fit the R32 door/body holes. doesnt look too out of place either.
new left inner steel guard. no more rough cut one.
close up of new left side inner steel guard - showing part number
shot taken through the front screen area with me standing up. shows the test fitting of both inner steel guards. they fit perfectly.
right side brace after a quick tidyup with a grinder to remove the spot weld points. the underside has bee painted with copper weld paint.
right side area where the new panel tucks behind two other pieces of steel. this is inside the wheel well and will need to be resealed.
this wasn't that hard to separate and remove the old piece of metal . putting the new one back in place will be interesting to watch.
test fitting - right side panel
passenger side (left) showing how the panel tucks behind two other pieces of steel.
test fitting left side guard
something I found when mucking around with door boots. this one is off a Z11 Cubre from door. fits perfectly.
whilst its not the 'correct' item it does make the placing of wires a LOT easier.
not at the moment. quiet season fro the shop so I'm personally watching funds myself. when I have a bit more spare cash I'll start working on it again.
I did manage to separate the sump from the engine block last week but thats about it. at some point I'm going to talk to a diff shop and get the actual condtion of the front diff sorted out.
stuff that is next to buy:
GTR intercooler brackets and plumbing. I have found these bits locally in brisbane and asked the shop in question to hold them for as long as he can.
I may get under it with a rag and thinners through the week and do a bit more cleaning.
found $20 :)
thanks go for FATZ for the fuel filter bracket and associated bits.
I have started storing things on the car now. it makes it a bit easier to see what I am missing as far as small brackets go.
I have a redundant set of GTR front indicators and GTR guards with NEW inner liners that are up for grabs - shoot me a PM if youare interested. I'm keeping the GTST guards .
it doesn't look in proportion front to rear with the GTR stuff on it.
the funds from these go to new GTST inner liners and new front GTST indicators.
the ties were the first thing I bought from wurth. they do a couple of nissan variants and I use them in my daily duties. I have a source for the slide on bolt type as well though they are a mazda item.
the proper trim clips will be a nissan only thing. whilst wurth do copies the OEM ones are actually cheaper.
another image :)
this was a before shot of a crack in the rear lower drivers side door jam.
that crack has now been ground and and shows me where a very quick cut/shut was done on the car.
for those that are looking at these cars for a daily or project take note of this. if you see anything like this take a 17mm socket to the seatbelt mount and pull that trim off. you will probably find a sectioned c pillar like I did when I started this project.
the up side of this crack is that I have to buy a new rear side for the car and that fixes several rust spots along the way.
the inner rear guards , paenl behind the fuel filler (where the filler neck comes through.) and the lower inside wheel arch.
this also means that instead of using PART of the new sill panel I get to use all of it.
anyone know how the rear of this car goes together?
from what I can see the rear sides go on first the roof goes on last.
actually - does anyone have a panel shop book for a R32 chassis. that would help me immensely in pulling this car apart correctly.
ok just ordered a new roof panel - to suit a sunroof based 32. reasonlably cheap at just over $675.. figure I wil see it in 6-8 weeks.
metro nissan - you rock!!
ok roof is HALF off. I started cutting spot welds about 45 min ago. B->C pillar points - loose, top rear window area - cut and loose. will do the front tomorrow at some point after I close the shop.
decided to redo teh body side of things first before I start on other aspects of the car.
bear in mind I am doing most of this panel removal myself with a bit of occasional verbal guidance from a mate of mine who is a panel beater.
his words today were - you are doing this quite well - done it before ? I replied - no first time I have done this and it is a slow/patient thing.
he agrees!!
I'll put up piccies later :)
this is the forward lower part of the right rear guard. when I bought this car it was full of crap. that is the result of crap build up and a good hit with a wire brush.
the inner guard is getting done so all of this will go.
pile of crap that I prised out of the rear right guard. the big chunk is kah glass.
rear lower right guard. that pile of crap was filling all of this. the hole goes through into the rear area - the rear panel (with hole) is fine
top inside of the wheel arch. that will go once the rear guard panel comes off
start of the roof removal - the spot weld tool I bought makes light work of this. I have a new roof on the way for it and the only reason I started at the top was it was teh last penel to go on. I have to do a rear quarter on this car and taking the roof off is the neatest way I can see of doing it short of cutting up a perfectly good $700+ panel. the grind mark to the right middle of this image is where the vehicle was cut/shut roughly. that panel will come out once the rear side comes off.
the faint gold line on the C pillar is the factory brass seam. those are on all 4 corners of the roof and are fairly easy to find once you find the first one. I can use brass rods so once this goes back together that is how I will put it back together.
    • Fark what are the changes of that snapping like that, clean. Nek minnit, custom radiator goes in, with built in oil cooler like those discontinued PWR ones from yesterdeacades ago
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
