I just changed my RB25DET injectors to 740cc Tomei injectors. I am having a really really heavy petrol smell when i drive/stop/idle my car, is this normal? its really heavy petrol smell, no joke............my whole house can smell it if i didnt close the door to the garage when i get home........ any other way to make it not smell that heavy?
DOesnt sound tuned properly if its running rich as hell.
Do you have a cat converter?
pretty sure i have a cat converter , i have to ask my mechanic about that man, if he tuned it running too rich..i probably need to ask him retune it.....i will give him a call tomorrow to make sure! thanks
The fuel indicates leaking injector seals. Leaked fuel vaporize and you smell it through the cabinet. It will likely to leak or leak more violently under high boost pressure.
haha that was freaky, didnt read the whole thread before posting.. identical thoughts just worded different!
i smell it in and out of my car...............driving me crazy man!! so smelly!!!!!!!!!
champ if it is leaking from the injectors, the smell could be the least of your worries if your still driving this vehicle.. fire is a mutha f*ka in your pride and joy
get it sorted asap.
fire? are you serious?lol........i need to wait till next mon or tues to get it check man but i still need to drive this beast to work tomorrow!
If fuel is absolutely pissing out at the injector (but we don't know where yet), it's possible fuel can get inside the injector plug and start a spark that will ignite the fuel in the enginebay.
from what i see, there is no fuel/oil leaking around my injector......but i cant see some of them ...its inside the thing.......
If you paid a mechanic to install these injectors, you should take it back to him to find the source of the smell.
And yes, the smell is vapor. Vapor is the thing point in which fuel goes boom best.
yea taking it back tomorrow for them to check , i can smell it really heavy in my car as well.....not just outside the car :S
    • Hooley Dooley these things have some history! If i sell them they will need a certificate of providence to prove they have been in the hands of verified RB20 royalty! They have been stored in a plastic tub, away from sunlight and moisture. They are in mint condition. And they will stay that way, as i have sprung the money for a set of shockworks coilovers. I'm just working on getting them in at the moment, after rebushing the rear of the car, and while the subframe was out i welded in the GKtech reinforcement bracing as well.  They will get a workout at Ararat King of The Hill in November. I ran 48s on the short course there a few months ago, and i am hoping with new bushes and shocks in the rear i can launch a bit harder. There was a fair bit of axle tramp when i tried too hard off the line. a few of the corners had dips mid way which also made the car feel a bit unsettled, hopefully this will help there too.
    • Food for thought, the stock oil filter thread is a 3/4-16 UNF, which has an ID of about 10 to 12mm (according to ChatGPT lol). Now compare than to an 10AN, which has an ID of about 14mm (Raceworks is 14.2mm, Speed flow is 14.27mm).
    • Yep, totally get that. However hooking in for Generator back up is only a few hundred bucks for the wiring. You could put a couple of those in (for different circuits explicitly) and run a couple of baby generators. Bonus, you can balance them across different circuits, and now have backups in your backup. I'm looking at buying places that won't even have water etc, and I don't mind the idea of getting off the electric grid either, even with everything you've said. This country already has enough power outages that even the mains grid isn't that reliable anymore. I do agree though on spending a bit more to get better gear, and to add some extra redundancy in to the system too.
    • You can set hard reserves on your battery system, and it can't be discharged past that.
    • That sounds like an excellent idea. But total self-sufficiency means exactly that. You have no-one else to blame when your system faults out and you have no power for a week or two while it gets fixed. You'd have to go the whole hog and get a diesel genny and all the switchover gear, to get you through such times. And, despite the fact that over 20 years, my system has been pretty reliable**, I have seen so many inverter explosions (or less dramatic deaths), panel and roof JB fires, and so on, over that time, to know that the stuff is the same as any other bulk Chinese manufactured stuff. The failure rate is well above zero - both on the equipment and on behalf of the meth addled installation labour force. And then..... warranty and means of redress against the supplier you bought the gear from. Best I can tell is that only a handful of solar companies are still around within 5 years of starting their advertising pitch. They disappear and phoenix like crazy. So, as per 1st paragraph, I suspect the only way to is go balls deep and spend maybe 2-3 times as much as you might think, so that you have every base covered. Plus, know and understand your gear intimately, so you can diagnose problems, sort them out yourself, etc, etc. Plus, probably have to consider upgrading various parts as the years pass, to maintain compatibility with newer stuff, performance and reliability, etc, etc. Whereas, remaining attached to the grid has an ongoing cost that keeps going up even if you use bugger all power from it. But it does provide the fallback in case of the worst case with your own gear. You either pay up front or as you go, I suspect.
