Proudly Presents:
Micolour SAU-Vic DECA Motorkhana ROUND 4of4 of the 2010 DECA CHAMPIONSHIP
When : Saturday 20th NOVEMBER 2010
Where : DECA - Shepparton, 145 Wanganui Road, Shepparton, VIC 3630
Cost : $85
Max Entries : 50 + Reserves
-= PLEASE NOTE =-
The insurer of the event (AASA) has issued supplimentary regulations that require all entrants to wear helmets during all competition. This includes the skidpan and all battles.
This also impacts passengers, as they must also now wear a helmet prior to entering a competition vehicle.
A fire extinguisher is required by all entrants. This is for your own safety.
Please re-read the supplimentary regulations before entering the event.
Entry Form & Supp. Regs. : ENTRY FORM
FILL OUT FORMS COMPLETELY. INCOMPLETE FORMS WILL NOT GO ONTO ENTRY LIST.[/b]
***Also, if you are emailing you entry, please name the attached file after your full name and what page it is. eg. 'Ryan Bell Disclaimer'.
Event Schedule: EVENT SCHED
Results: Not yet available
All withdrawles will be refunded after the event. Refunds will not be given after 5pm Monday 15th November.
Anyone paying by cheque MUST make the cheque out to Skylines Australia Victoria. Cheques made out to anything else WILL BE REJECTED.
Please support our sponsors : Micolour - Custom Refinishing, 7 Dissik St Cheltenham 3192, Ph: (03) 9555 8011.
  • Replies 165
Entry List
1 Ryan Bell Micolour Sileighty
2 Michael Eichorn R43GTR
3 Russell Cunningham R32GTST
4 Chris Thomson R33GTR
5 Ross Brown EMO6.5
6 Troy Brisby R32GTST
7 Jack Kuzior R33GTR
8 Adam Newton EVO4
9 David Lee 135i
10 Daniel Church S13
11 Tim Williamson Micolour Sileighty
12 Joy R34GTR
13 Matthew Femino R32GTST
14 Luke Distanislao S14
15 Ash Cosgriff R33GTR
16 Srete Cvetkoski Clio
17 Grant May R33GTR
18 Rob Nigro R32GTST
19 Sean Power S14
20 Mark Pisani R33GTST
21 Edwina Andrews S13
22 Tom Giordano R32GTST
23 Tim Bryan R33GTST
24 Mark Ryan R33GTST
25 Dean Course R33GTST
26 Andrew Richmond R34GTR
27 Leon Stapley 180sx
28 Hayden Taylor s13
29 Shane Janssen R33GTR
30 Alan Calleja R33GTST
31 Hamish Hampton R33GTST
32 John Packham 200sx
33 Jimmy Wong Liberty
34 Glynn Matthews WRX
35 Che Boocock R33GTST
36 Ben robinson R34GTR
37 Daniel Hall R34GTT
38 Terench Ho R33GTST
39 Gerald Tan Supra
40 Antony Ivancic R33GTST
41 Alex Skrekovski EVOX
42 Roman Plotnikov 180sx
43 Harsh Gupta R33GTR
44 Jake Lowry 200sx
45 James Sherman S13
46 Megan Vansteensel Supra
47 Steven Skrekovski MX5
48 Tony Skrekovski Audi TT
49 Dave Talbot S Ute
50 John Kypri R34GTT
51 David Hurst R??GTS4
forms ready to go. just noticed entries are stated as open 11/10/2010 so i'll send them in tommorrow.
exceited. fingers crossed next time i will enter in my Skyline :P
see you all in shepp.
Probably a dumb question, but how do I fill in the first part of the disclaimer.
I/We ...........Kieran............. of .....................?????................... being then entrant/s....
What do I put in the second part? My suburb, family name, car club? Its probably something really obvious I'm overlooking.
your name, of address.
example. I/We David Talbot of 64 Frankston Flinders rd, frankston.......being the entrants
:D
Its more for non privately owned cars, ie workshop owned cars that arent driven by the owners. Still want full names in there though. Addresses are fine also.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
