Not usually a big fan of Fords (except for the ol' GT's)
But APS have released an absolute monster of the car.
Check it out here... http://www.aps-xr6t.com/falcon/avalon/307kph.htm
Threre are gunna be some very quick Fords around very soon methinks.
https://www.sau.com.au/forums/topic/33990-307-kph-ford-xr6t/
RedFox: The next generation Commodore is supposed to sport a quadcam 3.8L V6, with some form of forced induction tipped... especially in light of the success of the XR6T....
Personally, I think the XR6T is awesome and could lead to good things :D
https://www.sau.com.au/forums/topic/33990-307-kph-ford-xr6t/#findComment-681435
barrp! snap.. barrrrp! snap.. BANG!
XR6T going down the strip, snapping second and third... then leaving the contents of the gearbox on the road.
love the motor, hate the gearbox.
Have a mate who works in Ford R&D he claims it is the most unsuccessful car for ford Aust ever in terms of recalls and failures with respect to the gearbox uh oh :D
https://www.sau.com.au/forums/topic/33990-307-kph-ford-xr6t/#findComment-681477
Ronin, why bother with that POS manual in the XR6T when you could bathe glory of the four-speed auto? It is handling some big power from tuner cars in standard trim.
Ford's stripping weight out of the 6T for Series II and will unleash a 280+kW 6spd FPV version soon. Second "Golden Era" of Aussie muscle.
Holden's new 3.5L quad-cam, all-alloy 4V-per cyl motor is rumoured to have a turbo hanging off each bank of cylinders as well. Not huge power, but massive amounts of torque. They're also gearing up for the new 6.0L Gen IV V8
https://www.sau.com.au/forums/topic/33990-307-kph-ford-xr6t/#findComment-682045
all hopes were pinned on cars such as the magnificent Lamborgini, Porsches, BMWs etc to post some of the fastest speeds ever seen from production cars.
I dunno about rules/claims for this... but the XR6t that was tested was no-longer a production car in my eyes.
Unless the Lambo/Porches etc were all modified too (which im doubtful of)
The Vic XR6t's that are running 11's have had money spent on thier Auto's.
The Nizpro one has had such, 100%, it was in a article they participated in and said it needs mod's to the trans that they can provide to make it last
https://www.sau.com.au/forums/topic/33990-307-kph-ford-xr6t/#findComment-682238
Yeah, well I'll say one thing. I hope Holden and ford do have a 6 cylinder turbo rivalry, it may pave the way for turbo's running in Aus touring cars again???
Bring back those bad ass Nissans!!!!!
(Hey Skaifie!, is that the new GTR wiv da twin turbo's and da blah, blah, blah)
https://www.sau.com.au/forums/topic/33990-307-kph-ford-xr6t/#findComment-682665
Aus can now start to lay claim to building some of the best/quickest saloon cars in the world.
You can sling mud and say they ar heavy, but what do BMW, Jags, Mercedes and Audi weigh, the local product is doing rather well in my eyes.
That said i cant justify the spend for modern cars, ill wait until i get a company car before i worry about what the manufacturers are offering... but an F6 Typhoon sounds the goods
https://www.sau.com.au/forums/topic/33990-307-kph-ford-xr6t/#findComment-683659
what is it with all you guys saying "lets see gtrs racing in touring cars"....where have you been, just on this forum theres a team in touring cars with 2 GTRS and a silvia :)
But, on topic, isn't it great to see tubros in the Aussie mainstream again? Its been a bloody long time since the VL tubro.
https://www.sau.com.au/forums/topic/33990-307-kph-ford-xr6t/#findComment-684235
what is it with all you guys saying "lets see gtrs racing in touring cars"....where have you been, just on this forum theres a team in touring cars with 2 GTRS and a silvia :P
Sooooo! you're tellen me that there are 2 GTR's and a Silvia running in group A this year against skaifie etc.....??????
https://www.sau.com.au/forums/topic/33990-307-kph-ford-xr6t/#findComment-684731
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
