Prizes and Awards:
Trophies will be awarded for "Best in Show" in the following main categories:
• Godzilla class (32, 33, 34 GT-R, one for each) & Best overall GTR
• Godzuki class (31, 32, 33, 34 GTS/GTT one for each) & Best overall GTS/GTT
Which R32 class?
  • Replies 168
Oh bugger – totally forgot to update about some things.
1. NDSOC (Nissan Datsun) are there also, just next to where we were. So there will be some sweet old school Zed’s and there. So this will be a HUGE HUGE show’n’shine potentially holding over 100 cars.
2. We have gained a “elevated” area to park cars on – I will decide which cars go there (cars like Matt’s 34GTR, Scott/Johns R32 GTR replica etc).
3. Entry plan has changed slightly. I will do a map shortly. Essentially it’s the same, we are just using a new gate. I will post this later tonight.
And the big one…
I need help – I need to make 2 ramps to get cars onto the elevated area
I plan to do this on Sat as Calder looks like it’ll be cancelled weather wise.
Anyone willing to come and help? I will do it outta wood, cover all expenses etc. Just need someone to bring a saw and a few other bits.
Probably start about 10am, measure it up. Then go to hardware store and buy/create some magic :whistling:
So it does kinda help if you are good with your hands etc at this stuff – if not it’ll just cause issues
If you can help out it would be appreciated, it’ll be worth the effort I promise that much :)
i can help sat evening...will try changing my shift for saturday to make in the morning instead of arvo so i can help.. :whistling:
will let you know...
what kinda tools you looking at that you might need?
i can help sat evening...will try changing my shift for saturday to make in the morning instead of arvo so i can help.. :)
nothing special.
just saw, hammer... it'll be fairly rudimentary style, but it'll work :whistling:
it’ll be worth the effort I promise that much ;)
come on boys, this is code for reacharounds... start volunteering!
would love to come and stickybeak (at the show n shine that is) but have exams a few days later :(
so sleep for 2hrs and then come :(
I've come direct from nightshift to events before!
also looks like ramp stuff is sorted.
thanks to Dan, we are checking it out Thursday night now. problem averted at this stage ;)
looks like we might get a visit from the aus rotor club as well. one of my friends has organised a cruise for them that day, and theyre route takes them right past our show... so they might be stopping to take a look at some real cars :D
should we be getting ready for a rumble? O.o
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
