"dimple" Neodymium Magnetic Sump Plug Group Buy!
  • Replies 200
Sump, gearbox and diff really (the diff and gearbox will actually shed the most amount of metal).
I can't think of any thing else? Maybe on a GTR transfer case aswell?
Count me in for the next one.
Will certainly go for the Gearbox, Diff and transfer case ones as well.
Here I am thinking it's going to be a wussy magnet just for tiny particles;
It couldn't get the candle holder off the benchtop but it was damn close!
Got mine today,
Thanks again Phil
They are quite strong little things, Think I'll do like everyone else and get a gearbox and maybe diff plug next time, there fairly wicked little magnets
EDIT: Didnt understand the black hole magnets but now I get it.... Key word was 'outside'
I was thinking they went inside the filter for some reason lol. Never mind my stupidity haha.
Callan
Edited by 89CAL
Awesome, that means the QLD boys got theirs today, the lower states probably tomorrow and WA probably on Monday.
Yeah they wrap the whole way around on the outside of the oil filter.
For the next group buy i'll go into a bit of detail on the Black Holes.
same.. But i assume its cause he's from mackay so closer to townsville.. any word on finding sizes for diff & gb? i'd be down for the black hole magnets also.. Just add me and let me know price if you source them..
Ah ok, yeah you guys are probably right about the Mackay thing.
Still waiting to here from EJD001 regarding the diff and sump plugs. I might PM him.
Edited by PM-R33
Just a heads up guys, it appears no one in the ACT has received theirs yet (any other states?) so don't stress, should hopefully still be on it's way.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
