"dimple" Neodymium Magnetic Sump Plug Group Buy!
  • Replies 200
Sump, gearbox and diff really (the diff and gearbox will actually shed the most amount of metal).
I can't think of any thing else? Maybe on a GTR transfer case aswell?
Count me in for the next one.
Will certainly go for the Gearbox, Diff and transfer case ones as well.
Here I am thinking it's going to be a wussy magnet just for tiny particles;
It couldn't get the candle holder off the benchtop but it was damn close!
Got mine today,
Thanks again Phil
They are quite strong little things, Think I'll do like everyone else and get a gearbox and maybe diff plug next time, there fairly wicked little magnets
EDIT: Didnt understand the black hole magnets but now I get it.... Key word was 'outside'
I was thinking they went inside the filter for some reason lol. Never mind my stupidity haha.
Callan
Edited by 89CAL
Awesome, that means the QLD boys got theirs today, the lower states probably tomorrow and WA probably on Monday.
Yeah they wrap the whole way around on the outside of the oil filter.
For the next group buy i'll go into a bit of detail on the Black Holes.
same.. But i assume its cause he's from mackay so closer to townsville.. any word on finding sizes for diff & gb? i'd be down for the black hole magnets also.. Just add me and let me know price if you source them..
Ah ok, yeah you guys are probably right about the Mackay thing.
Still waiting to here from EJD001 regarding the diff and sump plugs. I might PM him.
Edited by PM-R33
Just a heads up guys, it appears no one in the ACT has received theirs yet (any other states?) so don't stress, should hopefully still be on it's way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
