I am looking at going down for both days as really need the seat time after having not driven my car in anger for about 3 years.
I will be sorting accommodation in the next 10 days so if you are coming down then may be able to sort accom
http://www.piarc.com.au/files/Nov%202010%20Sprint%20Regs.pdf
I just need a 1:51.9 and I will be stoked :P
https://www.sau.com.au/forums/topic/340973-piarc-sprints/
  • Replies 49
Mmmm. so tempting! I was planning on going to the SnS though...
My issue is that I have slotted brakes that don't have slots anymore! and need new pads...
I was hoping that winton was going to be my last blast with these brakes so I didn't need to spend any more money on this setup before I put on my G4s.
PI is hard on brakes right? or does the flowing corners mean less big stops?
https://www.sau.com.au/forums/topic/340973-piarc-sprints/#findComment-5504004
Its fairly hard on brakes, esp into Honda. i think its only right that you set a decent time there before you go and turn your car into a sports sedan, i wanna know how quick you are round there :) Would be a good comparison to compare to when its done too.
Piarc days sell out fairly quickly right?? how late can we enter??
https://www.sau.com.au/forums/topic/340973-piarc-sprints/#findComment-5504165
Yeah I might head down for the Sunday.
I wanted to do a Sandown day before the year was out, but time didn't permit, so this might be the only option for some track time before the year is out.
Luke has entered the S14 for the Saturday.
https://www.sau.com.au/forums/topic/340973-piarc-sprints/#findComment-5504199
Looking at the entry form. Are we class H? Over 3000cc modified?
Cash on the day coz I don't have a cheque book?
There is nothing about it on their website.
Yep only the sun for me bris...assuming my entry is accepted.
Russ, the classes don't really matter as it is more for the PIARC people doing their championship thing I think. I believe the turbo multiplier puts us in the over 3000 classes.
Cash on the day should be fine....was last time I did a PIARC day.....if you want confirmation email the event sec Teresa at [email protected].
https://www.sau.com.au/forums/topic/340973-piarc-sprints/#findComment-5510172
i'll get my car running first. ive pulled all the epa un-friendly parts off of it. if i go, i'll be going with just a exhaust and cooler. which would be good in a way, as i wanna go just to suss out the circuit.
https://www.sau.com.au/forums/topic/340973-piarc-sprints/#findComment-5512614
quick question re scrutineering.
they say 2 bonnet secure methods, are they insisting on bonnet pins ? aiming at older cars that don't have a spring catch and a lever'd saftey latch
it ain't obvious! and i'm considering the saturday event.
https://www.sau.com.au/forums/topic/340973-piarc-sprints/#findComment-5514877
It means 2 'methods'. The standard latch is only 1 method.
Pins or a belt will work.
https://www.sau.com.au/forums/topic/340973-piarc-sprints/#findComment-5515379
    • Yea I could, but it is amusing how shit a stock seat and belt are
    • Just to be clear, there were no lights or codes when the hiccups were occurring. Also nothing noticeable in the cars' braking. It brakes fine and the dash is clear. I only made the connection when it did throw a code and suddenly, despite the lights, it felt great again.
    • Yeah they are sliders and this was in my head before I worked out it was the speed sensor.
    • Ok so we have a smoking gun.  A few weeks ago I had to replace a speed sensor that I'd fit incorrectly. I replaced the sensor and everything was fine with no lights or codes thrown any longer.  When I was doing some more bedding in yesterday I got ABS and traction control lights again and, considering when this happens those things are disabled, the pedal went back to normal with smooth braking and no hiccups.  The codes thrown are for the same speed sensor that I replaced. When I looked at the sensor I took out it looks like the tip of the sensor is damaged. So whatever happened to it, perhaps it has damaged the magnetic ring on the bearing (that I only replaced the other week). I'll get my boroscope in the hole where the sensor goes and see if there is any damage in there. Hopefully just the tip of the sensor is in there and the bearing is fine. 🤞🏻  It's worth noting also that the pedal hiccup happens more often and for longer periods now and totally goes away when the codes are thrown again which happens usually after 5 or so minutes of driving. Love all your help here as usual guys, thanks!
