What turbo is running on the motor? What is the rest of the setup?
At the moment stock. But as soon as i can get this all planned out, it will be mated to a GT3582R and a custom intercooler with a Greddy core, managed by a haltech platinum sport 2000. I am also in the middle of selecting the cams.
you started the thread saying front facing plenum was better for reponse and now we hear your putting a 3582 on it anyways, not exactly a responsive turbo selection...
the hypertune plenum isnt that much more than a greddy or plasmaman item, so how could that be more than your willing to spend if your still after a quality item...?
custom intercooler, not cheap
haltech platinum sport ecu, not cheap and easily cheaper options that can do the job
yet hypertune plenum is more than your looking to spend, I dont get it, surely a budget constraint didnt play a part in your selections so far?
Are you doing the installs yourself, otherwise again, not cheap, add on another $2K there at least... and not a mention of exhaust yet...
Yep. Have had one on mine for about 3-4 years, great quality bit of gear, what you want to know?
For the OP the way I see it you only really have a handful of choices depending on what you want:
Greddy manifold
Plazmaman plenum (However this doesn't sound like what you want since you want a full replacement manifold)
Custom Hypertune manifold made to fit a RB25
Custom RIPS plenum
Or something completely custom by a fabricator to your specs
Those are your main non "Ebay spec" options. The first two are the cheapest, bolt straight on and have been trialled and tested for years.
The next two will most likely be the best quality but the top dollar stuff. Whether your setup will benefit from them over the first two choices is probably debatable.
The last option could be the best, could be the worst, could be the cheapest and also could be the most expensive. Obviously way to many factors.
For your setup, while the intake manifold will play a good role, I don't think it is the vital key to the setup and any of the choices you make from the first four will work fine.
My 2C.
Edited by PM-R33
Yes hypertune have awesome inlet manifolds the R&D put into them is unbelievable. they can custom make one with no problems there, but the cost would be most likely be more then i am looking to spend, plus they like to have the car to do it. It is a shame really.
i bought one 2 weeks ago and it was 2100. the price has come down heaps in the last few months. when i first started looking at the beginning of the year they were around 2550.
im pretty sure they dont make one for the rb25 as i enquired last year when i started my 25/30 and crd said they dont make them at all.
Greddy manifold
Custom RIPS plenum
My 2C.
far enough all fairly reasonable. Best response i have had so far. i am trying to steer clear of the plasmaman option as it will most likely cause the plenum to foul on the bonnet.
they can make them but they prefer to have the car so that they can makes sure for sure that it will bolt straight up, they are fully custom units. Still around the same price from last i checked then
for the amount of money some of you guys are talking for a manifold, I can make one with custom runners, 80mm billet throttle body and billet rail and all polished....oh and did I mention able to flow more than any of them!!!! similar to the pic below. that is for an rb30, but the concept is the same.
and yes it will accept the IACV
Edited by ISL33P
How much you charge for one of these to? to suit RB25 with the billet fuel rail and throttle
Cheers mate, they look good
$1200 for the plenum
$430 for the 80mm billet throttle body with tps and plug
$230 for the fuel rail
+ delivery which is usually around $50
With a total of $1910 you are looking at a complete intake side for any rb series engine....compare that in price and flow/power potential, it is very hard to beat
Edited by ISL33P
how much hp can ur manifolds flow efficiently. hypertune (102mm version) flows 1400hp+.
ive asked before but u didnt give me a power figure.
cheers
julz
Edited by GUN_METAL_GTR32
That's a generic question considering they are all different and it can depend on what the customers wants from their engine.
Strange that I haven't answered it in the past because I usually do.
If you are talking about the rb26, it flows enough to support well in excess of 1500hp and that's with an 80mm throttle body. I usually don't recommend anything larger than 80mm. There are somethings to be taken from the different size throttle bodies used but not something I will do in a public forum.
The single cam rb30 plenum pictured can flow in excess of 1200hp and again with an 80mm throttle body.
The best thing about the it how well they flow between cylinders and proven on some recent dyno testing (using individual egt's to measure results) to support the flow tests.
I take pride in making sure all cylinders flow as even as possible and combining that with maximum flow.
Let's just say that the bellmouth size, design, plenum volume and throttle body size should all be matched - edit: when there is little or no compromise for performance
94mm is more than enough for anything you throw at it. Just as an example, there are some guys in the US making over 2000hp and using a single 100mm, is this the most effecient setup? it could be argued either way....and if there are any RB pumping out those kind of numbers, I would love to have a look at the intake manifold to see what thought has gone into it and compare it to what I have seen.
A lot of the time people just go for the look of the 80mm throttle body....but having said that, I have seen very very good results from 80mm throttle bodies on your little ca18/sr20 all combined with a good plenum design.
Edited by ISL33P
IMO in order to gain a benefit out of these short runner intake manifolds you will need to spin more rpm.
Generalising.....if you are going to drive it in the stock rpm band then stick to the stock manifold for the best overall power/torque curve.
I agree with this guy. Long runners for stock rev limit.
If you want less intercooler piping the Plazmaman is the go.
cheers
julz
a question relating to all this manifold business how much power can a stock inlet handle i been looking everywhere and cant find the answer
    • What an awesome idea to fit the facelift Lamborghini Diablo headlights. They are a perfect fit!
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
    • GT-R clearly the better choice! The 300 is certainly not insaly fast but has a decent amount of poke. Does a nice little drift around the corners with a decent amount of throttle. It's VERY predictable in a slide too.  Feels so progressive! People probably presume there's a 25 year old driving it based on my behaviour this week! 🤣
