  • Replies 43
Posted Images
if it's all stock you could maybe get away with a 5, probably leaning towards too hot though.
Yeah pretty much esp with stock coils to use the BCPR6ES as yeah you get better contacts, also VL Turbos run them so out here in the boonies at least I know I can get them just about anywhere. You could probably use the -11 (denotes 1.1mm vs 0.8mm gap) given you have it pretty stock.
okay, taped up the packs and put the new plugs in and yeah. same shit
so im gona buy new packs :P
pics of plugs...
bottom plug is 1st piston etc etc
sorry about the quality.
now the 4th plug has a sticky residue on it.. fuel?
Why didn't you try the coilpack elimination first like I said? Now you've gone and wasted your money on plugs and it didn't solve it...
Add learn to read the whole thread to your list of things to do, including losing your virginity Mohsen :)
ehh, adds to the learning curve
boz- they all have commos on chopped springs haha
anyway, buying an ignitor off a fellow forum member :) read on another forum a guy had the exact same problems as me and it was the ignitor.
Edited by Mohsen
if you're not getting it for bugger all, then it's stupid to replace shit if you don't know that it's that causing the problem. I'm sure anywhere in the northern 'burbs you can find a mechanics with a beat up R32 out the front to swap parts from lol
coil pack 1 is farked!
tried putting some silicone (again from the coilpack thread) to see how it goes and yeah, nothing.
any chance its the ignitor playing up?
what happens when you swap coil pack one and two then do the coil pack elimination thing that Birds suggested? does the miss move to where you put the suspected dud coil pack? If so it aint your ingnitor
this stuff is pretty easy you just need to use logic to isolate the broken bit
you dropkick i told you last night in vic wasteland to investigate the igniter!
He doesn't listen mate! I say let him spend his money lol.
Could be the loom plug for cylinder one, ignitor...or fuel related.
okay guys
ignitor arrived
swapped it in
small improvement overall but still nothing in cylinder 1!!!!!!11
i took out the loom and had a good look at it, seems the actual plugs have deteriorated. will get it checked out tomorrow and post up the results
You are such a twit! I'm surprised you didn't just buy a new engine and cut out the middleman. I understand what you said about the learning curve but yours is more like a quadratic.
birds, im narrowing it down.
checked out my loom properly, looks like plug 1 was crushed internally. so i cleaned it out. will try and connect the - connectors to the + ones on the coil packs when i get home
if it isnt that
then ill move onto injectors.
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
    • Fair enough, I am in no way a tire expert so I'm not familiar with all the terms and conditions. I'll definitely note down the AD09 to potentially try in the future. Rain is not too big of a concern for now as I will probably only drive in the rain when I have to. And considering I still lack experience driving the GTR I'd more than likely take it easy too. I have coilovers in the car but as I barely got to drive so far I never bothered to even check if they are adjustable haha. The suspension is almost entirely old and worn as well so I suppose when I eventually fix that in the future that would make a huge difference.
