They are getting out. I'm a pleb and the 6258 GTR kit we bought off the shelf. no special favours etc. ordered and paid for it and it turned up a week later. I know the big frame stuff is a different story but they are getting there.
lol. they should be awesome.
Consider this. look at the EFR range and consider the 9180 flows 94lb/min. a single 6258 flows 44lb/min I would say it's not unreasonable to expect them to produce 80lb/min combined in a twin GTR set-up. that's 800hp of air.
the car they are going on has run 2530s/-5s and made the usual 350kw or so. it's also run GTRS/-10s and made the usual 400+ kw but with typical surge down low that's a pig to drive through (even on the track).
I would like to think these will be close to the -10 power but with close to -5 response. I wouldn't be disappointed if they make a little less than the -10s but without the surge down low and with fat midrange.
I'm not sure if anyone else has bought a set from full race for a GTR apart from the one in the US they tested on. so this may be the first 'retail' set that goes out the door.
hope to have them arrive next week.
The other turbo I got from BW/FR is here and has already been pipped up etc and should be running very, very soon. it's the big boy 9180. another mate of mine has a 8374 coming soon so it'll be interesting to compare the 3. in power terms it goes 8374 then twin 6258 then single 9180. I'm keen to see if that's how it plays out in real life and what kind of power/response compromise we get. the only difference really is the 9180 is on a 3L the other 2 are both 2.6.
What 9180 did you get housing wise? Still waiting on mine, paid Nov 13 2010. Quite depressing so far. I am fabbing a 321 stainless manifold and will need it to complete the manifold. Guess we'll see. At this stage I can still see it being a LONG way away. Which, quite frankly, doesn't impress me too much.
Edited by -Totenkopf-
totenkopf. it's a 1.05 twin scroll (ext gate). yeah we ordered last year too. I know BW have had production issues and I guess want to make things right before filling orders. hopefully they are worth the wait (I think they will be). hope you get yours soon mate. :)
Correct! Common ground met.
All is fair in love and war. We got to learn and clarify a few things and I got to push a few buttons when all I originally wanted to say was the 6boost collectors are sexy.
I blame STATUS, that prick he stated it. :whistling:
Anyone want to have a stab at the projected RWKW of the SR flavor of the month EFR?
Imagine how much quicker it would be with a Vipec! :whistling:
But back OT, from what your saying Mr Baron, you guys are seeing exceptional low rpm performance from the big 9180, so much so you would be happy to see more lag with a larger turbo. So realistically for someone such as myself also running a 3litre but only aiming for 550rwhp with a power ceiling around 600rwhp the extra expense of say an 8374 over a traditional t4 ts gt35/s300sx doesn't seem worth it (if you follow my logic). Obviously in a forum pissing contest it's a no brainer, but on the racetrack...?
yeah I see your logic. I guess for a 3L that's already going to achieve the power and response you want with a more basic TS turbo then sure there is not a huge advantage in the EFR, but you can have your power goal and even better response wouldn't you want it? in a street car it will be noticeably faster? the other option these give then is have the same response but more power by going up a size in turbo.
I still think the kick arse GTR set-up will be these twin 6258s. but the singles make an impressive set-up and simplicity of a single (even a twin gate TS one) is something to consider too.
I know, It was a bit tongue in cheek....My bad.
Yeah, If I had ordered a twin kit I would be rolling now, I'm waiting for a 8374 T4 .92a/r IWG.
....But we have 8" of snow in Christchurch yesterday, So couldn't drive the car anyway! haha
Crazy weather eh? I can see snow on the hills around me right now and I am in Welly ffs. Wellington wind is bad enough without throwing ice into it.
Hope something shows up for you soon enough man, quite keen to see how you find it after previous combinations :)
yeah it doesn't look like final set-up and complete testing will be done before WTAC due to a few snags along the way. but once done I'm sure BW and FR will want to make the results public. we've never published any dyno sheets etc from the car before but the way it performs on track is a pretty fair indicator of it's performance. so for now it's still work in progress....
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
    • Any idea where I can get genuine MAF apart from used ones? I can't find any only for GTRs and unfortunately that price is not in my budget 🤣 I might gap my plugs down and put my splitfires in, they were only in for a year or so before I started the rebuild
