Wouldn't welding on a T3 flange to a T2 housing result in just a little bit of turbulence? ..Not to be a prick, but I have a T3 setup as noted and I WANT a 500HP EFR...
no problem, here is an external photo of this procedure done properly. ill try and get an internal photo next time we do one.. spend some time with the die grinder
Edited by Full-Race Geoff
That is a porn rear housing right there. Is the temp probe port tapped from factory? Or is it just a cast section that's designed for the job...
I like the trumpet outlet, very nice. It would flow much better than the garrett/Tial single angle outlets I am sure.
all external-WG EFR turbos (1.05 a/r T4 also) have that nice velocity stack "trumpet" machined into the outlet like that. That bung you see was part of the prototype housings. it was used to record preturbine 'EMAP' to determine the optimal A/R size for the production housings
That looks like a Tial V band housing, do you have any pics of the process on a T2 EFR housing?
that photo is a 7163 vband EWG prototype housing for use on an R35 GTR high power build. Weve done the same to T25 also, in fact recently did it for the Modified Magazine Time attack S2000 build. ill try and grab a photo later today of this housing conversion for you
Wouldn't welding on a T3 flange to a T2 housing result in just a little bit of turbulence? I mean considering the side of the T3 discharge to the T2 entry.. I like the idea but I am not sure this is sound advice :S At least not without better instruction or insight into a successful procedure.
I'm with you. T3 single scroll EW, in a size that my SR20 can spool. You'd have an instant customer.
I don't understand.
They have the 6258, 6758, 7064, 7670 and 8374 available in T3....
I'm a follower of the IWG but do you really need the EWG to kick some ass... Really? They have many different models but people always seem to want what isn't produced. Can't win. I'm sure you wouldn't be disappointed with the IWG, even if you're a hater, you'd be surprised. Less piping too.
But really if you're gonna want a large EWG turbo (guessing you want 500whp?) but want the small frame spool, you should look into a stroker kit, rb25 or even rb30........
I'm affraid the explanation is fairly simple. My existing exhaust manifold is made for EWG, deliberately, because I think its neater and provides better boost control. All I'm saying is that I'd readily upgrade if the option of a bolt on affair were available
Its exactly the same for both of us. I already have a really high quality T3 manifold kit and simply need to pick my T3 flanged turbo.
That being said, I feel the 7064 might not suit.. And the 7670 might be bigger than I want to go. I do want 500whp once everything is pushed to its edge, rather than having 600whp up my sleeve and pissing in the desired result. Its just a methodology I want to maintain in my build.
In this case the 7163 is both a little heavier breathing AND has the mixed flow turbine which I am extremely interested in.. This flange swap is also an excellent idea because I can get a housing smaller than .83 AR and which will be friendlier on my SR.
I am with Tom Tucker and will be a near instant customer if a 7163 that suits my needs is available (subject to real world affordability).
Amen good Sir
  • Like 1
Anyone know how much shipping is for turbo + mani ?
From Fullrace? I was quoted US$420 this time last year for FedEx International Economy 7-10 day delivery.
EFRs have jumped in price $400 since then so it's pushed it outside of my budget :(
US $420 for shipping? That is outrageous.
RSP have not charged me a dollar over $150 USD for shipping on orders with MULTIPLE items including a turbo. Thats $150 USD for a turbo, gates, and other odds and ends all in the one box. Even that I thought was somewhat pricey, but the items would arrive in just over a week. Multiple members on this forum can confirm that RSP charge that sum for a turbo and it is delivered in roughly 7 business days.
Let's just fix some expectations here... We don't need to pay $2,200 for a turbo and $420 to ship it.
http://www.ebay.com.au/itm/BRAND-NEW-GENUINE-BORGWARNER-7064-EFR-SERIES-HIGH-PERFORMANCE-TURBOCHARGER-/121175171912?pt=Motors_Car_Truck_Parts_Accessories&hash=item1c369a6348&_uhb=1
The above seller has a 7064 T3 .83 AR for $1,700 USD and $150 USD shipping. The seller has 31,000 sales with a 99.6% positive rating. Thats nearly $800 in savings, and considering the eBay add has a 'make an offer' function I would be disappointed if I couldn't knock $30 USD off the price, which WOULD make it a saving of $800 USD.
*rant end*
Actually my quote was for an EFR 8374 which is now US$2600.... hence why it now exceeds my budget.
That's ~$3K for a turbo + taxes/duties.
Money no object its a fantastic turbo, but bang for buck it's doesn't deliver $1000-1500 worth more performance over say a GTX35 or a PT6262 BB
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
