Best Place To Buy Black Silicone Joiners In Melbourne
Hi All,
As the topic suggests I am trying to find the best place to buy some black silicone joiners to replace my factory rubber. Is there a shop in melbourne that people know of that is a good price and good quality? I hate the monza brand that autobarn have plus they dont have black.
I was hoping to find a physical store instead of an online store if possible, unless someone has a really good online store to recommend?
i know of this place near repco in oakleigh...not sure you already know about them...seen a lot of blue silicon hoses but you can ask them if they have black...give me a bit and ill try to find the name of the place...
VPW
122-128 Cooper St
Epping VIC 3076
(03) 8405 9200
cheap and awesome.
EDIT: http://www.vpw.com.au/category.asp?CatID=7...mp;SubCatID=985
Wow those prices are fantastic! Thanks heaps!
$35 for a bend in 3"? ouch.
$150 won't last long lol.
just look on ebay, same shit stuff, just cheaper.
be interesting to hear if the VPW stuff is reasonable quality or not.
2.5 inch last time I checked :P $28.43 for a 90 degree bend
Theres only 2 of them, but yeah it is still going to add up.
Spareco
8 Park Road,
Oakleigh, Victoria,
3166
They have some cheap stuff and good quality ones. They got lucky dip tubs where me and my mate bought less than $5 stuff that worked great. Never complined about the hoses bought from there so will recomend it.
Purple Pig. Can't remember if they're in Ringwood or Bayswater, but around that area. Sell heaps of silicon joiners and been recommended to go there by a few people in the auto trade for stuff like that now.
any truck parts shop would have them
Ok i tried this and they actually have blue and black hose but its not glossy its a matt colour, very stealth in black..Which is cool..And pretty cheap
On the corner of stud and canterbury rds mate next to TTF kinda...They have other stores around too..
  • 1 month later...
http://www.vpw.com.au/category.asp?CatID=788&SubCatID=985&priorCatID=788
another thumbs up for the VPW stuff.
been using it for years now and never had a single failure.
have had ebay crap and other brands that has failed on customers cars when they have supplied it. replaced with proflow silicone hose and never had a single issue again.
yep go for truck part shops, they will never break and last a billion kms given the reliablity requirements they have
also should be cheaper and not mega shiny
    • jeebus. glad you weren't under it while performing the stunt. Also thanks for the link to the wheel measurer, exactly what I needed
    • In the older stuff there were very significant differences 2wd to 4wd, for example Stagea had strut front end for 2wd and double wishbone for 4wd so it was not minor to swap. From poking around the 2wd v37, it *looks* like it might be more possible; some of the parts specifically have "2wd" stamped on them which suggests the platforms are more similar. You'd still want to start with a 4wd half cut to swap stuff from though. I'd suggest if you don't have a tune on the ECU you don't really need one on the trans either. Throttle mapping is in the ECU side (and you can always use a Roar Pedal if you want the throttle to actually respond to your foot), and really if you are happy with the stock power you probably accept the stock trans behaviour too....its all made to be "sporty" not racey.
    • So, updates. I have not washed the car since it came back from Tassie. I've driven it around a bit but not got around to actually sorting it out. I DID raise it because I cracked the rear bar leaving a hotel which was very distressing. Interestingly, the car drives more compliant now that it's raised a fair bit (5mm front, 15mm rear). Also noticed that my FR height was 10mm lower than FL. So that's now sorted out, too. I also bought this and had it printed: https://www.etsy.com/au/listing/1576422240/wheel-and-tire-fitment-tool-universal?ref=shop_home_feat_1&dd=1&logging_key=08f604d9fa4cc383550ba985e6ac85cd5cac7fbb%3A1576422240 Now, if I was smart I would have taken my brake calipers off to actually use this correctly but it was evident enough to me that in the region where the caliper was... there was nothing to hit suspension/guard/arm wise. So I'm going with "it'll be fine" after using the tool to hopefully very precisely measure the wheel clearance. Also while doing this, I had the very VERY bad idea of jacking one of the wheels/suspension arms up while the rest of the car was on jack stands. I did this to see how the arm would travel. This all was well and good until the car slid off the stands and went through a fence. So don't do that. Incredibly nobody was hurt and there was only minor damage to the rear bumper as the car didn't have far to slide, and had 3-4 wheels on it. The only damage turned out to be the fence itself which was easy to fix, and a little bit of damage to the fibreglass rear bumper trim. I had already planned to try a touch up paint kit to fix the time I drove into my garage door to see if it'd help in the interim before I get it fixed properly. I used the Dr Colorchip kit after looking online and seeing everyone talking about it. Yes it's made for chips and not huge broken missing pieces and I'll be 500% recommending it for stone chips after using it for stupid things like me. This took about ... 10 minutes and looking at the half assed photo the 30 second job I did on the bumper corner was almost perfect just by using the tiny little brush and painting it in. The sealact stuff to remove over-painting is really useful, so if/when I do it again I'll likely slather the touch up paint well over it and then clean it up with the cleaning solution. The wheels should arrive in a couple of weeks. I am still kinda confident after doing a stupid amount of measuring (and borrowing a set of 18x10.5+15) that they will not fit because I overlooked something, somehow and flew too close to the sun. ALSO R34 GTR guard liners do not fit on a GTT. I bought the undertray brake duct guides and had the wonderful problem of them not fitting my intake, my oil cooler and the liners themselves were even worse. Attempting to fit them won't work in general - You would have to cut them up as another poster mentioned as the bodywork is different on the GTT. At least I can try to resell them. So instead of cutting those up, I cut up my old already-cut-up GTT liners and extended them by using some PP plastic and drilling some 8mm holes for some nissan clips for the 'extra' bit. Because I was happy to cut them I was able to mount them pretty damn forward so I now have some semblance of guard liners, and the brake vents seal the bumper from the bottom. It sort-of-looks like this, to give some idea - If you look at the GTR and then the GTT this is when I realised that I needed to seriously measure as the inside of the rim area is entirely, entirely, entirely different and could not take any internet measurements for granted.
    • If you are Ecutek tuned then these TCU tunes are anywhere from $550 to $700 usd. If you are not ECUTEK tuned, then it gets costly!
