Car has:
BLITZ 700cc injectors (most effiecient lag time of all 700cc injectors) $600
BLITZ K5-660r ($2800 new)
BLITZ D1GP manifold (made by their race department, not a buyable part) cost $2000new
BLITZ 47mm Gate with dual screamers. $1000 new
Mega responsive (full 22psi by 4000rpm) 400rwkw setup on BP98 @ 22psi, made 420rwkw on e85 before the injectors ran out, i envisage 460rwkw on E85 @ 22psi
$3800 no offers (if it doesn't sell it will go on my Aristo as i would rather keep it)
ATI 1000hp balancer and water pump pulley (200km old) $600
GREDDY oil Pump (200km old) $700 pics below
RB26 EAGLE H-beam rods $400
New Greddy coil-overs (setup for RB 12kg and 6kg) have original 8kg and 6kg springs too. $1200
Full R32 GTR rear Nismo Arm kit ( lower and traction arm all new) $400
Front s15 NISMO control arm (will fit r33 or if you want to widen track fit to s13 and r32 ) $250
Zenith guard bracing (extensive chassis strengthener) $250
rebuilt steering rack $100
Adjustable toe arms $100
Uras castor rods $200
Uras extra lock tie rods and spacers $200
Super Now tie rod ends $100
Nismo 2way 5000kms $800
R32 GTR cradle
5 bolt shafts not the weak 6 bolt
Str8 thru exhaust with twin rear bozuku flutes $150
oil cooler kit $200
Greddy 115mm intercooler ($2500 new) $600
Greddy radiator (r32 gtr) 1000 new $600
tomei fuel pump (sold) $350
Powerfc d-jetro and all sensors $1200
R34 GTT box bought with 17000kms $1500 can supply it as push or pull, currently setup as push (r33)
BLITZ twin plate (top of the range ORC) $1200
5 stud conversion, S15 front spindles, R32 gtr rear brakes, r33 front brakes, Blitz MR3 pads ($700 when new rear unused, front 80% left) whole lot $1200
whiteline sway bars adjustable front and rear $250
half cage suit sunroof $350
drift tacho and oil temp, oil press, water temp gauges $300
nardi steering wheel
vertical hydraulic handbrake with booster for one finger actuation (std still in place and working) $250
drift kevlar passenger seat with s13 rail $250
2 x sets 17x9 +15 uras ns02 all round with new toyo proxes 4 tyres $1500ea set
High Uras GT wing $200
Uras clear tailights $120
Genuine c-west bonnet $420
Super Made 180sx headlights (see pic) $150ono
much much more or take the lotl for $15k or will split over the next few weeks
  • Replies 54
Posted Images
hey there how much u asking for the full turbo setup? and what turbo is it
$3800 no offers (if it doesn't sell it will go on my Aristo, its just to good to sell)
Trent its andrew with red sil80 if you can, hold the guard braces and gtr subframe till i get back from japan if possible..... but if get buyer selll sell sell!
    • You will now be able to lift the parcel shelf trim enough to get to the shock cover bolts; if you need to full remove the parcel shelf trim for some reason you also remove the escutcheons around the rear seat release and you will have to unplug the high stop light wiring from the boot. Next up is removal of the bracket; 6 nuts and a bolt Good news, you've finally got to the strut top! Remove the dust cover and the 3 shock mount nuts (perhaps leave 1 on lightly for now....) Same on the other side, but easier now you've done it all before
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
    • And I just realised that that advice is slightly nonsensical for a GTR, because you need 2 of them. But it is otherwise true.
    • Having had a reasonable look at the car, I'll be able to remove the (one time) rams and retract the hinge (they are held in the down location by a tiny (m3?) sacrificial screw) which will get it physically back in shape. From there if you remove the rams you need a resistor to turn off the airbag light (as Mark said, there are plug in kits and I might go that way because its reversible). And...per all the threads on here, even if you have the resistors to turn off the airbag light, the bonnet light will stay on as it writes to the airbag computer history - that is either replace the airbag controller, reprogam the EPROM (if I can work out how), or remove the globe from the dash. Having seen how sensitive this system is, if I had my time over I'd pre-emptively remove the rams, even on a road car, because this is all a very unnecessary pain in the arse. Reminds me, time to go and have a look at the Fuga too....
