I have a set of R33 GT-R wheels on my car at the moment, but would like to see how much I could afford to offer W1ngnut for his epic wheels if I sold these ones first. I'm not sure how much these usually fetch, since condition would play a large part given the age of the wheels.
Currently there's a decent amount of very minor gutter rash on a few of the wheels. This is entirely cosmetic - none of it is bad. Wheels have never been damaged. All have centre caps. All currently balanced with current tyres
Tyres themselves are so-so. Rears have horrible camber wear on the inside, but outside tread is still good. Can't give a %, but they wouldn't be considered legal given the camber wear. Fronts are perfectly legal, HEAPS of tread left.
Throw offers at me guys, but no point low balling me as I'm not trying to get rid of them - merely seeing how much people will pay. I WILL sell them for the right price though.
Will ship at buyer's expense for interstate sales, but would naturally rather a local sale.
https://www.sau.com.au/forums/topic/342285-eoi-r33-gt-r-wheels/
bah lol....nah sorry man $1000 would be the lowest I'd go. Like I said, I don't need to get rid of them....just figured if I sold them, I could then cough up and buy W1ngnut's GTC's :)
no worries, offer still stands later on if your interested, like I said I don't need the rubber, so you could sell that seperately. at least the fronts.
haha no worries :)
I'll drop my lowest price on these depending on whether the GTC's go down much :P
yeah Eiji, 17x9. they're currently wrapped in 235x45 MAXXIS. Not terrible tyres by any means, they actually did quite well until I upped to almost 400rwhp :P
haha I'm not trying to sell them Mel, I don't think people quite understand that bit :)
I'm merely interested in W1ngnut's GTC's, but no way I could possibly afford them without having first sold these. It's not like these wheels are surplus to my needs or something :P
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
