Genuine R34 Gtr V-spec 2 Aluminium Pedal Group Buy!
What are they out of? They are drilled ones though, and I hate drilled ones (done it once before, pain in the ass lol) and also illegal because there is no rubber on the clutch and brake.
no idea, just found them on yahoo auction said was for r32/33/34 GTR...
but your right if they are drilled cbf,
please put me down for the current Groupbuy if there is enough spacers
I'll chuck you down for the next batch as the first batch was only an inital buy of 10 to test the waters.
Just awaiting three more payments from the first group, I will send a quick reminder to those three later on and hopefully I can place the order on Monday
:D
if not mistaken they're nismo pedals for the r34 gtr.
Phil: "Hello, I would like to order R34 GTR V Spec II pedals"
Nissan Japan: "No worries at all, how many sets would you like?"
Phil: ".....All of them."
Nissan Japan: " :blink: ............umm please wait one second....."
Phil: "............."
Nissan Japan Boss: "Hello, you want ALL of our R34 GTR V Spec II pedals?!?!?! :devil: "
Phil: "Yes please"
Nissan Japan Boss: :O
Edited by PM-R33
...and then some years down the track someones doing a ground up rebuild of an R34 GTR V-Spec II and is looking for new pedals but its no longer in production and is completely sold out... but there is quite a fair few used R34 GTR V-Spec II pedals that pops up on eBay here and there :devil:
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
