Abandoned my brake upgrade.
Apparently, despite being told otherwise, R33 brakes do not fit all Stageas! :P
Now I need R34 brakes, but I've blown my money on R33 brakes.
Can't be f**ked anymore.
ruby, i'm assuming you are having problems with the caliper mounting bolts being different sizes? r33 is m12 and your car m14?
if that's the case, just get some sleeves machined up (pretty sure you could prob buy them already done somewhere as it's a common issue) that are 14mmOD and 12mmID to fit into your knuckle and use the m12 bolts to fit the caliper :P
all you need to do is find a metal supplier and see if you can buy some 12mm i.d. pipe with 1mm wall thickness
which will have a 14mm o.d.
also, re-bled my fronts, pretty happy with the pedal
all seems good :P stops well now
No. Far from it. The legs on the Sumitomo calipers are too short (in radius) meaning even dummying the calipers in place, the 297mm rotors are too large for the calipers suited to them (on the R33). I even toyed with dummying in place the 280mm rotors and the calipers still fouled on the rotors (even when I spaced out the offset).
So the R33 GTST calipers and 297mm rotors have the right offset, but totally wrong radius (by about 20mm); and
The R33 GSTS calipers and Stag 280mm rotors have the wrong offset, and still wrong radius (by about 3mm).
Something to do with the 14mm bolt pattern for the calipers being close to the centre of the hub.
Sounds to me like the R33 calipers you have are actually R32 GTSt calipers.
Nope. Series 2 R33 GTST calipers and rotors. Pulled them off the vehicle myself. Sumitomo calipers are unfinned and rotors are not 280mm, so therefore definitely R33 GTST calipers and rotors.
They do not fit.
Might have found a set of R34 GTT calipers and rotors interstate ... so I'll be f**king off this useless set.
:P
They do not fit.
the mounting dimensions are the same from 33 to 34 and the actual calliper is very similar (pistons and things)
all that is really different on the 34 callipers is the length of the legs, but its only longer relative to the bigger rotor
eg, 296 to 310 = 14 so the legs would be ~7mm longer
yup i'm also very confused ruby
The basics of it all is:
R33 GTST rotors and calipers are a direct bolt on for series 1 Stagea
R34 GTT rotors and calipers are a direct bolt on for series 2 Stagea
Contrary to what I was told. R33 rotors and calipers do not fit ALL stageas.
Think I'll just leave it and get the 325mm Wilwood kit after all :)
Get some neg camber on that sucker - STAT!! 4mm different offset than mine (+22) and your's is full mexican!
I fitted my bluetooth adaptor for the headunit, so now I can take and make calls without worry of getting busted on the phone.
    • Hopefully it ends up being something manageable, like a hone, rather than a full bore—it would be a huge relief if it’s not as bad as it looks. Hang in there; these setbacks are annoying, but it sounds like you’re handling it as smartly as possible.
    • At the end of the day, it’s all about understanding the odds and being comfortable with the potential cost, whether it’s horsepower on a build or chips on a roulette table. And I have to say, the Laine example made me laugh—some people really do embrace that carefree, “roll and see” attitude!
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
    • https://yariksteel.ru/manual/R33/Skyline_R33_elektroprovodka.pdf   Page 18 should be what you want for the Dash Cluster wiring. Though, you don't need the dash plugged in to get the motor running. What you want is power as how GTSBoy said. You need to power the ECU. Find in the above link the ECU pin outs (Verify them before just connecting them up from things written on the internet). Find anything needing power, give it power, find anything needing ground, give it ground. Then give the starter motor power through a big cable, and bridge the solenoid on the starter straight to power too.  ECU will be on, and when you give the starter power, it'll spin the starter motor, and it should start. I also hope you have a proper stand, and not just the engine sitting on some wood. You will want it bolted down properly.
