Just (very briefly) drove mine with the revalved Bilsteins in the front: 1000000% improvement, but still a little work to do: bump stops still need to be replaced with slimmer items: the old ones were all but destroyed when the shock failed :)
Pretty impressed so far: hoping to have the car back mid next week, handling like it should (and used to)...
What are the offsets PetroDola?
Are they rolling or flaring the guards? The fronts are already "rolled" from the factory, the rears can be rolled.
Is yours a RS? let me know the offset and I can work out exactly how far out from the factory guards they will sit, or if they will foul the front control arm.
Ben
mines actually an RX the one below in my pic is the car in question.
I believe theyll be rolling the gaurds i know the fronts are quite rolled already but the rears will need doing. is the offset is 9.5?
Impulse by at jb hifi
cadence x1 sub package - 300wrms sub, ported box for the sub and 600w amp
$250 :D
now i can take the bass load off the poor 6" door speakers :D
thats the width. It should be stamped somewhere on the back of the wheels hub or spokes. You may also have a sticker on the inside of the rim.
Should look something like 19 x 9.5J +35 etc. 19 being the rim diameter, 9.5J being the width and a + or - number being the offset. Looking at the pics of your rims you would have a positive offset on those, probably around +30 or more. If its higher than +35 you will need to run spacers on the front to clear the front control arm, if its lower than +30 you will need to roll your guards.
So basically it will be perfect at 9.5J + 35 to +30 and you wont have to do anything other than fit tyres!
Edited by bbenny
Hey benny , its 19x9.5 +30 offset
i take it thatyll suit ok?
Thats awesome!
You shouldnt have to roll anything, Just be careful on tyre size, a 245 or 255? should be sweet. If you go something too wide then they will scrub the guards.
but +30 will look sweet! cant wait to see pics when they are on.
Edited by bbenny
Dont you hate it when people fake to go and the stop, instead of merging...........
Oh crap, dude... How bad? looks like the intercooler has had it, aside from the obvious panel damage.... :)
Made an executive decision to trade in the Alpine pre-boxed R-type subs I installed late last year, and permanently mould in the Alpine S-types I have sitting here into a sealed enclosure. I have no idea what I was thinking when I bought the R-types: ported subs are not my thing, but the ability to remove them for track-day antics was appealing.
Since I broke my back, track days are now off the table, so I may as well go with a SQ setup, which is what the rest of the audio system is geared towards... I figure using the subs I already have sitting here will save me a heap of money over the "buy a pair of X-type 12"s" option...
Very much hanging out to get the old girl back witht the front suspension sorted: a drive in a mate's '05 STi reminded me of how the barge should feel on the road, and I believe there is still a way to go...
achieved a bit for the weekend:
- fitted PIVOT speed meter and PIVOT shift lamp
- fitted red LEDs to the dash - now all interior lights are red
- sprayed rain gaurds gloss black and fitted up
- took back surface rust on rotors and sprayed them black with VHT caliper paint
- put on some hubcentric rings, has got rid of vibration at 100km/h
- used glassylite on the UV affected headlights (these things were shot, so yellow that i was trying to source replacements but this glassylite stuff has took them back to brand new - best 40 bucks i've spent on the car)
i have a list of 'to do' stuff, so it's getting shorter each weekend - but the more time i spend in and around the car, the more i find! its tough being OCD!!!
link to glassylite please
im getting sick of polishing them
fitted my sub on the weekend, good to have a ballenced stereo once again, just need to fiddle with the settings some more
edit, also painted the rear brakes in 3m blue caliper paint (same as the fronts) and fitted them
should have my speed bleeders soon and hopefully a firm pedal all the time soon after that :(
Edited by pipster11
Picked mine up again prematurely (so it's still got a bit of suspension work to do), because I managed to trash the front bar on the beemer yesterday: I mean, who thought it was a good idea to put boulders on each side of their driveway, right at the gutter end, where they're impossible to see?!
http://www.glassylite.net.au/
the trick is the 'nano sealant' - but just be careful with your quanitities, they give you SFA in the kit, so you need to make it all last.
hey mate i'd be interested to see ur sub setup, i did some measuring today and was left scratching my head.....
This is the current setup, but as stated, is subject to change completely in the near future...
    • Biggest thing is you're okay!   It sounds like between the accident, and the drive home, it was a pretty torturous trip again! On the bright side, you took the opportunity to enjoy the event more from the perspective of a spectator, than as an entrant!   Sad to see so much damage to the car. It really has taken a HUGE hit in the front end. If/when you choose to repair, hopefully the rails are straight (At least from shock tower backwards). Hopefully the extra cage coming through there has save most of the chassis rails, and HOPEFULLY saved the motor too. Best of luck when you eventually get motivated to start pulling it down to check it all out
    • Sounds more like what Brad said, that it's mainly transfer. What pad bed in procedure did you use, and did you replace/machine the rotors, or just swap pads?
    • The stutter is almost entirely in the pedal. I don't feel the brakes release and reapply as you would with ABS engaging but the pedal feels that way, without the brakes releasing. It only lasts for less than a second and the pedal is fine again. It's hard to explain, sorry.  I'll get under this weekend and just double check everything is tight. Fluid is at max where I left it.
    • What bedding in procedure did you use?   When you say stutter, what exactly do you mean? Like it feels like someone letting go of the brakes momentarily and regrabbing them again to get you to stop? Re-reading your post, and that is what it kind of makes me think you're explaining, like theres a little bit of a jolt, likely just as you're reaching a stop. I've only had this issue once. And if its caused by what caused mine, you will want to get the car up on stands again and check it over. Mine was a case of a caliper mounting bolt coming out and letting the caliper rotate on the other remaining bolt and gave play in a wheel as it came to a stop. But not every stop either!
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - then entered a hotlap with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - hopefully the motor and other things are OK but yet to be seen too. There is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it Effort doesnt win you races though     Apparently this is motorsport !
