got a new turbo to install in my car.... :P
what turbo!?
eyes andy suspiciously ... you havent been to jetwrecks have you ? ;)
argh i got delayed again with my suspension and tyres ..not till wednesday now *sad face*
also what difference did the plenum spacer make Dunc - i should probably invest in one of those and leave it on the shelf for two months also :P
I didnt notice the hugest difference with the fmic on a stock turbo.. in fact during the day a slight bit of lag , but a definate improvement at night.
Edited by PetroDola
At the moment, just a lighter wallet - could be because its sitting on my shelf next to me still :P
lol sorry dunc .. same boat as me ,
daleo .. you said it made a good difference yeah? :P
and someone here is making these who is it again.. and is there any left ?
Can i get one pls :P
Edited by PetroDola
daleo .. you said it made a good difference yeah? :)
Can i get one pls ;)
Yeah, bucketloads more torque in the midrange, there's heaps more with my new exhaust, so this is just the cherry, on the icing, on the cake :P . Only had about 40km of diving so far, I'll be driving to work tonight; that'll be a better test.
Jetwreck's your man, but I don't know if he has any left :P .
Cool thanks .. hope hes got some left :S
yeah the dump and full exhaust mod in one go was the biggest improvement my car has seen in performance thus far.
Went to start mine today - it's absolutely DEAD! The fuel pump wouldn't prime, and the alarm/immobiliser wouldn't even turn off.
The battery is fine, but there must be a major issue with the alarm or something. I drove it on Saturday night, it started fine when I was leaving home, but would barely crank when I went to leave my cousin's to come home again. :) Hmmm, if tomorrow is the same (weirder things have happened), it's time to call Unigroup to see if there's a mobile sparky they can recommend.
what turbo!?
eyes andy suspiciously ... you havent been to jetwrecks have you ? :)
He wouldn't let me near his turbo and yours is a long way away...
I had MY spare turbo rebuilt with a Sierra Stage 1 kit..
It will be interesting to see the difference it makes.
PM sent
Edited by Jetwreck
Took the front guard inner lining off to run some wires on the 25G. Down the bottom of the guard back towards the A pillar
was chock full of wet mud, so today cleaned out both sides. There was a good double handfull of mud in both sides that were making a very nice rust inducing enviroment. Had done the RS a couple of years ago.
test fitted my wheels! (18 x 9.5 +20) seem to have heaps of clearance atm as i have bugger all camber dialed in, i may end up running a 5mm slip on on the front to bring them out a bit.
ps. yes there rotas bring on the hate! i couldn't resist them at $999 a set with hub rings and a full set of aftermaket lock nuts.
Looks tough mate. I like it. Do Rotas just get hated on because theyre not JDM, or are they 'considerably' inferior quality? (not being a dick/trolling)
just a few...
and my personal favourite - the before and after track day photos
seen them all mate really doesn't concern me, believe me its an informed decision it is a daily only car but if they do break I will be the first to post them up. For the same sizes from rays 3-4 grand, just not worth it on a daily.
Edited by horrace
TBH a bit of both, they were shit back in the day, all those pics mike posted are old but people have long memories, there was a guy here on sau recently whos spoke cracked but he was tracking an R35 on full slicks obviously my car is a ton lighter and wont be tracked with slicks.
Saw that in the SA Wasteland thread, Nightcrawler had a small spat about it :)
Yeah you guys gotta get your facts straight - they were on an R35GTR doing insane lap times for 6 months, then while the brakes/wheels were red hot from many very hard laps he went through a BIG ice cold puddle and one spoke cracked. Any alloy if you heat it up enough and then dump it in freezing cold water will crack. It is not a reason to stay away from Rota's at all, but rather a hefty endorsement that they can take all that punishment.
you'll be right for daily driving i'd say.
a lot of them were circuit racing incidents - plenty of load put on the wheels
there was actually a member on here that stress fractured the rotas he decided to use as track wheels on his r35
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
