hmm picked up my BC coilovers, greddy boost controller, HDi FMIC arrived at the office!!
come on nismo products from japan!
A busy night in the garage tonight? :P Pics to follow I hope!
haha busy indeed!
tell us if you notice a difference with HDi FMIC .. i actually noticed more lag in the short end because of the stock turbo. but pickup in the middle range top end when it was cold at night (bearing in mind qld winter is 25C)
hopefully that will change with the hiflow.
got some tuning nuts today and replaced the stocky nuts with all 20 of the tuning nuts.
Should be a good deterrent for anyone attempting to steal the rims as theyll need to get all 20 off without rounding the nut and that wont be easy.
and ordered the centrecaps from rays.. $200.. (rip job)
Can park out front without being overly paranoid now!
Edited by PetroDola
Are they the Taleb tyres ones?
I bought a set, finish was nice, but I ended up running at tap down them as the threads were fairly gritty. Check them before you fit them.
hi duncan , not sure what brand they are , i got my tyre friend to source them for me from mullins wheels in SA (the bag had no brand names), but they were really good nice threads and clean.
i needed quite small ones for the key not to scrape the rim as its really narrow
Edited by PetroDola
haha im not going to install till the brake rotors arrive, then ill do brakes and suspension at once to save wheel removal time
i wish i could have done it tonight, had photo comp to go to instead
    • Not sure the US can import anything other than the C34 Stagea's, but if you can and you need to to tow, DO NOT under any circumstances get an M35 Stagea. If it is just as a family car and your country/state allows it, absolutely and definitely get an M35 (3.5L if possible as it is effectively a 350Z) over a C34.
    • Punch your VIN (nm35-xxxxxx) into Amayama.com You can see everything there quite easily.
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
