if anyone ever considers buying a 350z, seriously re consider.
Because of the fuel leak i have i decided to take my sister z to work.
can believe how shitty the visibility is out the windows, especially the rear one.
reverse parking? nah. you cant tell how close you are to the wall. have to get out like 3 times to check.
power? ehh.. good take off, in the wet, i struggled to keep traction, half asleep you have to really baby it. but then when you expect more power up top. nothing. the car seriously gives up at about 4000rpm lol.
oh n not to mention a PITA to get in and out of.
It makes me appreciate the stag and how comfortable it is.
POS 350z, i wouldve sold it by now.
/Rant
/Rant
LOL....should go and post this up at the zclub forums and watch them react...hahaha
Your sis got the VQ35HR engine right? That one's supposed to be better...
yeh shes got the HR model..its meant to be 30kw more or something..
but whats the point after 4000-4500rpm it literally just gives up. i think im expecting boost.
one other this i forgot to mention.
the speedo gage numbers are wayyy to small. personally i'de rather them larger as u notice if your speeding.
I dont know what the japs did with it, its a POS. im glad the 370z was a massive improvement.
I finally discovered the real reason why Craig buys Nankangs. They keep sending him calendars...
Edit: Fine, a link instead: http://livesniffpetrol.s3.amazonaws.com/wp-content/uploads/2010/12/PicNews-101203.jpg
Hmm good point. Make sure tagged links in future then...
Mind you, your work probably doesn't like you on SAU all day when you're supposed to be working either?
Well luckily for me I'm not on it all day :pirate:. See above as per Aaron's comments...
I'm sure other's might not appreciate half nakid (fat) chicks popping up on their screens when their boss/colleagues walks by...
If u really wanna share your luv for BBW's there's the wasteland thread for that...hahaha
Edited by ironpaw
especially if the colleague is a fat chick
just got off the phone with Shannons Insurance...
Not impressed.
1st - they don't know my car. That's fine, not many people do.
2nd - after telling them every little bit of detail about my past infringments/mods etc he comes back and says "we can't insure you because your car has too many mods. It needs to be in a garage"
3rd - I told him as I'm moving to a new house soon which HAS a lockup garage, can he give me a quote. He goes for another 10 min and then comes back and said "no, we can't give u a quote until you've moved into a house with a garage".
I guess I need to ring up again and lie just to get a f**king quote. idiots...wasting both our time. If they don't/can't want to insure me just f**king say so from the start...
Thank goodness JCI's online portal is so easy to use...
Edited by ironpaw
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
