Pfft, stop whinging, Craig - at least you can get your side pipe kicks in once in a while, and in a proper race car too!
Oh, I was at a group dinner with your dad and Terry on Friday night, and he mentioned something about someone being pulled over by the po-po, and them enquiring about how a black Volvo could accelerate so fast, is that the case? :P
Rofl...I'm going to kill him....yes they were going in the opposite direction when I popped out and opened it up to get away from 2 fools....did he mention that the guy I was trying to get away from had an accident 300m away from when I was?
Yeah he did mention that, what's the story there?
i once got followed by po-po on the way home, wasn't speeding but did took roundabouts faster than other cars...was still driving the civic (got coilovers)...
they followed me to my house, parked their car in my driveway and when i came out of the car, i told them to wait 5 mins as i was desperate to do number 2...lady cop was pretty nice to let me do my business (after i convinced her that we were in front of my house) and checked my licence while i was doing my businesswhistling.gif
long story short, once my business is done, i had to listen to her quick speech about not taking corners/roundabouts too fast pinch.gif, no fines luckily...
thats what ive never been able to understand. if someone in a ferrari did the same thing, is it ok because the car is designed to handle?
whats classified as taking off too fast? i was almost done for that in QLD, but talked my way out of it. so i got a ticket for an exhaust that was too loud. never paid the fine. got so many notices saying they will cancel my licence and rego. lol this was before some states could actually do that!
In response to your Ferrari question, I would say yes... but then again I think logically (most of the time).
Law makers would say no (but they implement changes only considering how much money they can make).
I was pulled over for taking off too fast a couple of years ago...
I just asked what I did wrong officer? You accelerated much too quickly
Did I spin my wheels? No
Did I speed? This is a 70 zone isn't it? No, you weren't speeding and yes this is a 70 zone.
Did I endanger any other road users? Anything could have happened at your rate of acceleration
And what happened? You were pulled over before anything could happen
Excuse me, but I was already at my intended speed before you pulled me over. Is there anything more I can do for you? Queue lecture on the dangers of "speeding" etc etc :no:
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
