all this car talk.....
in 5 years time or so, once Ive had the stagea for a dozen years, I'll be looking to purchasing an auto awd R34 GT-4 and drop my rb26 into it :)
the stags bottom end is slowly being rebuilt atm, piston rings on cyl#4 had hairline cracks, #5 piston had spat the rings and was cracked. she died a sad death. Minimal cost rebuild will involve acl bearings & cp pistons.
The RB from the track car, yes?
Why not drop that in the Stag?
yes Im really tempted to drop the rb26 from the trackcar into the stagea, but it comes down to finances & future plans/wants.
a gut feel in this case says to me its better to have two cars which can be sold-off if required financially, rather than a 10k engine being dropped into the stagea leaving me with a trackcar-shell and half-a rb25 motor.
