Missed out on the HPs, will try again tomorrow anyway. Apparently theyre porting gingerbread to it, so it won't be completely useless.
Still, I already have an ipad, so no real point.
Hi guys
Started thinking about accommodation for when I come down for the 15th anniversary cruise. Am looking at Travelodge Blacktown (is that place OK?), since it's fairly close to the meet point. Alternatively, anywhere on the way in from the north would suit also. Does anyone have any suggestions?
old
noni hazelhurst did one ages ago. yes thats the woman from playschool
Yeah, but it doesn't have the same attitude.
Aaron, here is the link for Noni's version
Edited by iamhe77
Hi guys
Hi mate, bankstown or blackstown.....????
It's Blacktown. The meet point is @ Top Secret Imports, Forge St Blacktown. Was thinking staying close by so I didn't have to navigate too far in unfamiliar territory. However, I don't want my car stolen during the night either.:(
LOL your ride is not safe in Blacktown OR Bankstown....:whistling:
Hi guys
in my experience, if you are going to stay somewhere average it may as well be cheap too. I've not been impressed with travelodges although I haven't stayed in the blacktown one.
Try the Ibis at Sydney Olympic Park its new cheap and close (1 freeway)
    • Hopefully it ends up being something manageable, like a hone, rather than a full bore—it would be a huge relief if it’s not as bad as it looks. Hang in there; these setbacks are annoying, but it sounds like you’re handling it as smartly as possible.
    • At the end of the day, it’s all about understanding the odds and being comfortable with the potential cost, whether it’s horsepower on a build or chips on a roulette table. And I have to say, the Laine example made me laugh—some people really do embrace that carefree, “roll and see” attitude!
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
    • https://yariksteel.ru/manual/R33/Skyline_R33_elektroprovodka.pdf   Page 18 should be what you want for the Dash Cluster wiring. Though, you don't need the dash plugged in to get the motor running. What you want is power as how GTSBoy said. You need to power the ECU. Find in the above link the ECU pin outs (Verify them before just connecting them up from things written on the internet). Find anything needing power, give it power, find anything needing ground, give it ground. Then give the starter motor power through a big cable, and bridge the solenoid on the starter straight to power too.  ECU will be on, and when you give the starter power, it'll spin the starter motor, and it should start. I also hope you have a proper stand, and not just the engine sitting on some wood. You will want it bolted down properly.
