yeh the s14.. im pretty happy man.
im gonna be jumping in a car that has had approx $70k of work done to it, and has receipts to prove..
completely rebuilt from the chassy up and engine rebuild and forged, less than 25,000 ago
So today we threw 4 blokes into the M35 and drove to Melbourne. Awesome with the TV screens, watching movies on the way over. Cracker! :thumbsup:
Just a shame our caravan park backs onto the Western Highway :(
Big Fella should be here later tonight, then tomorrow it's off to Calder for Gymkhana! Oh yeah!
First road trip I've done in the Stag since I brought it back from Sydney, and so far it's too easy. Just wish I had fixed the undertray before I came over. I race taped it and thought it'd be right, but the tape fell off. Very annoying.
yeah was thinking of doing a road trip too pity it was a 9hr drive LOL...........would've been nice if Ken Block came to Sydney also!!!!
Well, it's.... orange!
Hope you enjoy the new ride mate. Bet you'll wish it was AWD when it rains !
Was definitely a down grade, but I think I want a car I can enjoy for a little while. When the time comes I'll be jumping back into a stag
When is the changeover actually happening? Or, has it already?
Coming down for a peek when you have it!!
How much power she putting out? If the previous owner spent a boatload of $$$ on building the engine then I'm guessing 300rwkw+?
should be getting it tomorrow if everything goes well.
How much power she putting out? If the previous owner spent a boatload of $$ on building the engine then I'm guessing 300rwkw+?
its flow tested for over 350kw.. its running 225 at the moment on a fairly reserved tune. might get cihan or trent to have a quick look over it though..
How did you score that?
It was the demo car at musle car and I had to get it back to Nissan.....had ne etag so I took the long route.
Nearly went past isms house but I was a little tired after having a late night on sat after dad hit a wall in the r32. :(
So there has been a slight knock over large bumps from the front of my car that wasn't happening a couple of weeks ago..... so I put it on a hoist to check it today and found this....................see something missing on the rhs? I guess when they changed the struts over for compliance someone didn't eat there wheeties prior to tightening it :domokun:
Edited by MOUTH
Faark dude! That could've ended VERY badly; glad you went looking?
Very very glad, Really suprised its not making heaps of noise. Going to go to coventry fasteners after work hopefully they have a nut that will fit pinch.gif
Edited by MOUTH
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
