Are you saying that your mate has broken all of those cars?
what the hell did he do to them?
Diff mounts on every one of them, diff on two of them, 1st and 2nd gear on two of them, 2 x ZF boxes and other drivetrain components.
He drove them like you'd expect a performance Sedan/Ute should cope with. Considering these were brand new, 10yo+ Skylines shame them with regards to toughness
lol mate that is rubbish, auto f6/xr6t's have been run time and time again into the tens with stock engines, turbos and stock rear ends. even 9's. 4 spd auto was shit but the zf is a dam tuf box. manual utes have been known to break diff mounts with very rough driving, but still very rare. cv's and axle's do break but to someone with experience with last a very long time !!! your mate can't drive.
Nex question, did he get it under warranty or did he have to pay for all of it?
What utter rubbish.
Have you driven a live axle late model Falcon ute? I'd say no based on your biased crap.
Oh, and you do know my 1974 Datsun 180b has the same rear end set up as your uber-technological Commodore, don't you?
Funny enough i have as i trade them in all the time. Im not biased at all, i work for Holden but i dont own one. I would like to have a xr6 turbo or typhoon but after talking to a few techs who work on them i dont think i will. And nowhere did i state the the Commodore is " uber-technological". But why do Ford still use a live axle when majority of vehicles now can do the same thing but with a much better independant rear suspension. I do know that all the tech that is in the current model cars has been out in some form or another before. and that most 80's-90's jap cars had this stuff. But it is now available in mainstream cars that most people can afford.
And by the tone of your reply i get a feeling that im not the only one "biased"
Too much misleading info in this thread mate...
I'd take a look over here for specifics: http://www.fordxr6turbo.com/forum/
lol specifications of the vehicles maybe, but opinions...you post this thread over there and then you'll know what misleading information is :D
Warranty jobs the whole way, through grit teeth with the last one after they agreed to the full FPV cover (in writing) to the modifications ie chip, injectors & exhaust
So in other words your mate is a total no hoper who can't drive for shit?
Of course, that's assuming you're not talking out your arse.
I'm not biased, I just think you're talking shit.
The reason the Ford still uses a live axle is because it's more than good enough for it's intended purpose. Why waste money trying to engineer a new setup into a ute only for it not to be as competent as the current setup?
If you keep an eye out you'll see every tradie on the road who actually has to carry some decent weight in a Falcon as opposed to a Commodore. There's a good reason for that. Of course many have moved up to 4x4 utes now, but there's still plenty of Falcons rolling off the floor which are destined to be genuine work horses.
And even once that's translated to the performance side of things, the benefit of IRS over live axle in a ute is so insignificant that it's simply not worth the effort or money. Have a look at the last few Brute Ute series. Factory cars with a bit of suspension and engine work punted round. The Falcons and Commodores are almost identical. In fact, the Fords have had it over the Holdens for the last few seasons, but there's not much in it.
So much for your argument that live axle is shit.
You're obviously a complete Ford fanboi (unfortunately like my mate) he's also owned 2 x XY GT replica utes (Purple and Yellow) and to be honest they've been the most mechanically tough/reliable, yet he will actually admit that the newer Falcons are soft.
I can also point you in the direction of a few forum members here who have also found the same thing with their brand new XR8's etc etc nothing to do with driving ability (I'm pretty sure he'd dominate you on a track)
Until the rest of the drivetrain is up to hauling the weight of the car under decent acceleration loads, the engine is an awesome bit of kit, orphaned in a backward car
Your mate would be an exception to the norm then. As others have said up until 370ish rwkw a BF typhoon or the xr6t with the typhoon motor (Jun 06 onwards) are very reliable. The diff bush is a common issue and there aftermarket fixes around and a manual xr6t should have its clutch done if modded and at high power the ZF fluid should be flushed every now and again.
The mods you listed - chip (hopefully you mean a flash tune) injectors and exhaust shouldnt make enough power to cause any real issues. Well unless his tuner has no idea, a good tuner will be able to adjust transmission pressures and tune the torque delivery so the box survives. A bad tuner will pull off those 'torque tags' in the tune and probably cause the dead ZF boxes.
Either your mate and/or his tuner is an idiot if he's wrecked that many. That's not to say his tuner doesnt work well on other cars but he might not be up to date on the ford tuning scene.
driving ability has little to do with the damage to the cars. he might be able to lap around a track fast, but if he spends all of his time on the street limiter bashing, flooring it everytime he takes off, manually changing the auto box, and just generally raping the car then he is going to blow shit up no matter what car he has. he would be the type of person who if he had a 33 would have blown the stock turbo and possibly even the engine.
You're obviously a complete idiot.
I'm not a fanboi of anything. You're talking shit and trying to write me off as a Fanboi isn't going to hide that fact.
You can try and be sure of anything you like, but you're mate can't drive for shit and you're full of it.
How often would a LEMON car become involved in it?
hyperthetically it wouldn't be feasible to say that, the guy that has fked all those cars could they have all been lemons? stranger things have happened right? lol
That's wierd, my XR8 is supercharged and the ZF is fine.
Wow you are an angry little boy arent you. Aren't forums meant to be all about someones opinion. Just because you disagree with someone doesnt make them an idiot. One reason why you see a lot of tradies in falcon utes is due them being able to put an alloy tray on the back. Holden dont allow that anymore but if they did you would see the same amount of holden's out there.
But wait you will disagree with this and call me an idiot as well :down:
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
