Tomei is the same part as ARP? Who's leg are you trying to pull now?
You have a habit of pretending to know what you are talking about but in reality you have no idea. Leave the expert comments to the guys who actually have the expertise. Tomei run a widened step in the shank and use 6 point nuts where ARP run a parallel shank and use 12 point nuts. They also do not share common base material and are formed using different manufacturing process.
I guess the statement was in relation to the OPs want of a daily driver with no huge HP requirements and only wanting to rev to 5K rpm...?
Heaps of people running arp by the sounds of it on here with alot more serous engine builds than this thread is sounding like...
Lol calm down son
Well no points for guessing who you've been listening to.
As 75coupe was smart enough to realise, I'm not claiming (as you have assumed) that arp sell bolts to tomei and tomei resell them. I was simply trying to say that an upgraded bolt is an upgraded bolt. Arp bolts do well in a wide range of cars (including your friends one), so why spend more money than is required when the owner wants to ditch the factory bolts (your friend will also tell you that's an unrequired upgrade as way more than his target power level can be achieved on stock bolts) when that money can be spent elsewhere like going towards a tune for example, or even spent on something completely unrelated to cars.
Agreed.
ok well i got my engine bits today so ive got
1.Bare block (honed, standard bore)
2.Fully machined head
3.Crankshaft
4.Couple boxes of unlabled bolts :D
where should i start? i figure get the bottom end together firstly, i inspected the pump drive on the crankshaft and can clearly see that it needs the collar as its showing signs of wear and tear on the driving edges so im thinking get it acid dipped, get one put on and have the crankshaft fully reballanced as a first step.
i can use as much help with this as i can get so load me up with info guys! :ermm:
First thing id be doing is measuring it all again, just to be sure it is all standard. Was there a reason why this engine was stripped down for a build? Its gonna be hard to do it at our workshop, cause we dont have any bore gauges/dial gauges. I just used an inside micrometer to give a rough measurement on my bores, plus my pistons where standard size when i pulled them out of the engine. Its going the next size oversize anyway (86.5mm) so i should have plenty of room to play. Id also get it x rayed just to be safe cause they usually crack around where the head blots go through the block along to the water jacket. But yeah just basically re measure everything again. Then start ordering parts/do more machining if need be.....
If its not burning oil and puffing smoke and the bearings don't make any noise don't touch it, just lean on it until it explodes, then build a motor, no point taking apart a working motor for small power goals like you are aiming for.
Just get a highflow turbo (loads of power down low if you get the right one) and you'll make oodles of power under 5k, stock motor will take it fine as anything above 300kw will mean the power is being made from 5-7 not 3-5 like you want.
+1 for GT-RS
On the street there is honestly no need to rev an RB25 with this turbo very high, having full boost by 3k rpm means any overtaking you wanna do is easy. Its actually worrying how quickly they gain speed if you dont keep an eye on the speedo.
(But if you wanna rev to 7k every now and then they still have some punch :ermm: )
today i measured the top of the bores with the big verniers and all read around high 86.00 to 86.05 across all cylinders, i know this is a crude way to measure but its best i could do with the available tools so im pretty sure its on its first build. got told it was a running motor stripped down at 122,xxx so the head could be used on a 25/30 build then i guess he decided to rebuild it again with a different head? appears to be in good condition though, big ends were intact, no scoring on the crank but i did notice some heat discoloration around where the oil pump drive is, not sure if this is common though. the core plugs have been removed to inspect the water passages, no corrosion is present. going to get the block acid dipped just to be 100% though. also sticking with the hydraulic lifters and just running type-b poncams so i'll definatly be getting them serviced before they get refitted.
my aim is anywhere from 300>350hp atw safely and without having to worry about the motor breaking while im giving it a bit of stick on the odd occasion
So its 220rwkw-260rwkw - factory motor is MORE than adequate for that.
There is no reliability problem at all with that power level.
Your part list is long, expensive and overall pointless for that power goal.
Yeah refer to the service manual for doin the proper measurements, you could have wear along the thrust faces of the bores, and because its been re honed you wont really be able to see the wear until you measure. Measuring these are crucial before you put anyting back together. Few simple steps to insure you dont build a motor that smokes its head off, and piston slaps every time whilst its cold.
Well you could add all the mad fun forged bits porting and cams, just move your power and revs goal up!
Type B Poncams are for NEO heads.
If the head has the metal CAS you need the Poncams for a series 1. Part number ending in 020.
good call, meant to type, type-A :(
im actually considering not forging the motor due to pure cost factor (looking at 4>5k and thats not including a turbo kit) still would run uprated bearings, headstuds, main studs, cams etc.. if i tune it to around 300hp atw on standard rods and pistons would the motor still be reliable or should i just save and forge it anyway to be on the safe side?
why do you even need a rebuild? building a forged motor when you dont need it is silly, you get piston slap with forged pistons which wears the bores faster, just leave it stock and put a highflow on it, when it finally shits it self consider the rebuild then.
the motor will be reliable complete standard, they are reliable from the factory, why do you need to pull it all apart?
Edited by Rolls
im building a backup motor, its a diffrent one than the one in my car now. my current engine has piston slap when cold so this is why ive decided to build a replacment engine before my one shits its self all together and i have no engine at all
good call, meant to type, type-A :blink:
Ill say again, there is no need for ARP/TOmei studs on a stock motor, hell even a 600hp RB will be fine with new standard stuff.
You will go backwards using bigger cams with a stock or small turbo, any gain you make a 6000rpm you WILL lose down low, you keep saying that you want power up until 5000rpm...so why do you want big cams?
so just buy a spare stock motor, it will cost almost 5x less and will meet your demands.
    • What Duncan said sounds right. Also, it looks like they only have the driver's mat. Not the rest. Because looking at the diagram: KG4911 is just the mat for the driver. KG4900 is the full set if I'm not mistaken and discontinued.   But, it looks like they may still have the full set for the manual S2. Might be worth checking for the other models as well as they seem slightly different. https://www.amayama.com/en/genuine-catalogs/epc/nissan-japan/stagea/wgnc34/6649-rb25det/misc/G49 Man, I'm tempted.
    • I dunno about that as a blanket statement. Pitwork is Nissan's "Nissan genuine" thing, and for stuff like timing belts, I have found them to be excellent. Of course, for things like oil filters, you always use proper trusted brands anyway, not whatever the OEM has taken to using.
    • Ahhhh... If you were putting 12V to the led in there, that's likely made it very unhappy. Chances are how you put power, was 12V across an LED that's meant to only have about 20mA through it at peak, and a forward voltage of about 1.8 to 2.4 volts. That circuit is likely only a 3V3 circuit, and will have a resistor in series with the led too. That's my guesstimate on that light, without having touched one.
    • Another vote for installing them and see how you go.  I mean, you already own them, why would you not fit them?
    • I have had too many of those over the years, my cars have a toolkit or at minimum a cheapy multi tool thing because its too easy to be snookered by some stupid plastic clip that stops you checking the battery terminal isn't loose.
