Are we allowed a wasteland in here?
I know there used to be one.. but for some reasons unknown (before i got here.. hehe) it got deleted. All the other states have one. QLD shouldn't be the odd one out. The "whos who" thread is just degrading into general chatter anyhow.
Maybe its a good idea. Encourages some activity in here and people to get to know each other a little better. The VIC wasteland had some brilliant and hilareous moments but kinda silly having to resort posting in there when i don't even live there anymore..
:ghost:
https://www.sau.com.au/forums/topic/34318-qld-whoretown/
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
So it was *too* popular huh? hmmmmm.. new server.. new resources.. more facility to whore :) I donated, I should be allowed righht? :)
Although I did notice that they've gone and dicked with the working setup and the dreaded server busy is starting to appear over the last few days for some reason...
If all the other states have one and they're not causing a server drain, then its 'stateist' and we should form a revolt :D
https://www.sau.com.au/forums/topic/34318-qld-whoretown/#findComment-687675
viva la whore revolution!! meh.. on that thought.. i'm off to bed.. :D
I donated too, so does that mean that I can depart from my usual "high quality" posts, to one word posts and general drivel?
If so cool :Pimp2:
https://www.sau.com.au/forums/topic/34318-qld-whoretown/#findComment-687697
nah she just wanted to get out!!! dont blame her...............
there's so many aussies over here, it's weird........i feel more at home here than what i did when i was living in sydney......
gympie is a weird place........what's their import scene like??? how come no one goes there for crusies???
https://www.sau.com.au/forums/topic/34318-qld-whoretown/#findComment-687905
As far as I knew Gympie doesn't have a "Car" scene only a "Horse and Buggy" scene.
I can see it now..... "Check out my fully sik buggy moit. It has Apexi reins and 90 inch wheels and a massive 1 HP at the wheels moit"
https://www.sau.com.au/forums/topic/34318-qld-whoretown/#findComment-687973
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
