  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Managed to get today off, how good is it. Although I reckon I am busier on my days off than when I am at work. So far I have got the tyres taken off my BBS rims and put them in to get machine polished, picked up my new number plates for the mini, picked up the DBA rotors and race front pads for the R and paid Customs/Shipping and GST. Needless to say I am feeling broke. Has anyone else seen the white GTR for sale on the Moorooka Mile, not sure which yard it is in, only noticed it this morning, didn't bother having a look. Too busy. I am off to somewhere with air-con.
Start rant/
Work sucks arse I am so sick of little stupid plebs with no idea...
Also have the shits with turbo's deciding they don't like 1 bar...despite being rebuilt 10K ago....
Oh and I need to rob a bank to buy air con cause this heat is giving me the shits...
End rant/
its not too hot today.. pretty nice in fact in brissie with a bit of cloud cover. Got all the windows open. But i'm thankful my aircon *does* work very nicely on my car. Comes onto cold in a few seconds, which is good compared to other cars which can take 10mins before the aircon is working to full effect.
my aircon is weird
was shit when we first got, it would be running, but no cold air would come out;
took it to get regassed and was told it was full of gas (didnt need to be regassed)
then winter, didnt use it
now summer and it actually works pretty good, just takes a minute or so to get wound up
wonder what the go there was . .. . .
i do use the recycle mode now, perhaps that makes teh differnece.. . .
Hay guys
I am moving down to Bris vagas in a few weeks , about the same time as my 95 gtst arrives on the boat , I am new to the mod car scene and want to know who to see in bris to get stuff from and who to put it on for me , and ( last one ) who to finish off with a paint job ? Soooooooo looking forward to getting the car and going on a few trips around town , where it is NOT AS HOT AS TOWNSVILLE !!! you whiney little girls ROTFL
    • Yes that’s what im trying to decide. Should I do stock gtt box or enclosed or open pod.
    • Also, I note OP is in Melbourne, which begs the question... are you aware of how illegal your car will be with a turbo, and intercooler and any sort of filter change? I don't know how you can get past the "2 intake mods" "rule" that seems to exist in Vic. Fully engineered might or might not get you there.
    • If you have a turbo... then the ducting holes I used to feed the pod are not available because your intercooler likely uses them. If you have an intercooler, your IAT's are going to be goverened by how good your intercooler setup is. I'm yet to really see anyone check IAT with a snorkel/boxed pod/proper CAI versus and unshielded pod. It would be interesting! But I suspect that the differences would not be so noticeable as if you were N/A as the intercooler is where the air is being cooled.. and out in front where the FMIC would be is a pretty good spot for it.. When I was turbo I pushed the stock GTT box as far as I could and made some pretty good power out of it, and noticed on the street I never made the same power/boost. Then I did a before and after run with a pod filter versus the box and picked up about 9PSI from the same boost duty cycle and about 50KW instantly. I never ran the stock box again, and recently removed it for my N/A setup. The box is restrictive to a degree - Even with the V8 setup I noticed I picked up power by removing the box completely, so punching holes from the bottom of it to get air from the passenger guard *helps* but the most effective one in my case was simply having the ducts, a pod, and no box around it. In my experience, *more* air was better than cold air. The air (with ducts) will be cooled off as you start moving, and especially if you start moving fast (a race track). It actually moves around quite a bit as you can see.
    • Well you could certainly buy or build an enclosure for a pod in that corner of the bay. It is absolutely vital that there is a nice big opening to let cold air in to it from the front or underside, otherwise it will just pull air in around the edges from the bay, and if that air is hot, you gain nothing from enclosing the pod. There is lots of good evidence around (including on here, see posts by @Kinkstaah for example) showing that pods pulling hot air from the bay is only a problem when you're static or slow in traffic, and that as soon as you get the car up and moving the air being grabbed by the pod cools down. Although that will obviously vary from car to car, whether there is a flow of cold air to the pod or if it all has to come through the radiator area, etc etc. Obviously, the whole exercise requires as much thought as anything else does. Doing the lazy thing will often end up being the dumb thing. The stock GTT airbox has a cold air snorkel to feed it from over the radiator. Shows that Nissan were thinking. The GT airbox is upside down compared to the turbo one, yeah? Inlet at the bottom, AFM/exit on the lid? That might make it harder to route the turbo inlet pipe using the GT airbox than a turbo one. That would probably be the main reason I'd consider not using it, not that it is too small and restrictive. I'm looking at a photo of one now and the inlet opening seems nice and large. Also seems to have the same type of snorkel that the turbo one has. Maybe all that's required is to make a less restrictive snorkel/cold air inlet, perhaps by punching down through the guard like I did.
    • Also seen this as an option
