  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
nope! i'm trying to do a website proposal but procrastinating badly here..
yeah, we want classy whoring here everybody! no one word stuff :) Or i'll have to get out the whip and make you all scream like little girls
Damn its hot! Can't believe I work outdoors, time for a career change I think. Just noticed it has just peaked at 35 deg and I couldn't help but notice they have predicted 41deg for both Saturday and Sunday! Thats just getting silly.
I want everyone to check what there avg post per day is , then we can truly decide who is a post whore , and don't want to hear excuse's like ; I was away for a month etc....
I will start with my pissy little effort of about 1.2 post/day
oh yeah when are you guys going on your next cruise ?
haha, well i am, although i tend to whore right across the forums. Since i originally came from VIC and know most of the guys there, I can whore there two. I have a natural advantage :D
There is a meet tonight.. but its brisbane area.
hehe, maybe. You can easily just write one word per post. Thats not really a challenge anymore.
I dunno, I think its good to have something - encourages a more friendly atmosphere around here.. people can find out what people are like and not like.. vent pointless thoughts.. like the mosquito that I just squashed, and yet somehow it managed to crawl across the desk(??)
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
