in answer to previous query.. This russian site (!) but seems to be fairly accurate..
R33 GTS:
Price when new: 2,413,000yen = ~$28726AUD with the current aussie exchange rate
R33 GTS-T type-M :
Price when new: 2,898,000 = ~ $34,500
R33 GTR (non v-spec):
Price when new: 4,545,000 yen = ~$54,100
Guess the range is similar between a base level commondoor, GTS-T comes in at around V8 base commondoor level and GTR = about entry level Statesman here i guess.
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
hmmm..interesting.. looking at the trading post here.. basically NO turbo S13 under $10k. Not even any CA18DET's. They're all n/a and what hothead p-plater wants an n/a??
Methinks its time gordo got rid of the baggage that is the skyline aand went into the importing business!!
kinda funny.. not that you really need a stack of moderators though unless there are a heap of posts though. Wasn't Squizz moving, or had moved down to Brisbane or something ?? That was the last i saw of him.
Bit pointless to have mods that never come on, but i'm sure that will be sorted out eventually.
I actually had some fun with him last night in the wet...err that didn't come out right lol. My 32 and his cefiro i am speaking of. :D
Scott
Coming tonight? Um fill me in.... i am not on here all that often these days. Is there a meet?
If so, i don't think i'll be going anywhere....never do on Thursdays cuz of work the following day. Only go cruising on Friday and Sat. And plus, i live near ippy so it's a bit further away from roma street etc.
Scott
The one that says "Thursday night meet 26/02/04" :D yeah, its down yatala.. although that isn't too far actually. I been out to ipswitch area a few times, only takes 30mins.
Everythign seems a lot closer here i guess to me, getting around melb was a bitch at anytime.
.. its generally as most people have the night free, whereas friday and saturday nights they generally have other plans and the streets are too busy.
Its never really too late anyhow. Last one I was at home by 12am.
but thats cool
I think they have to have 2 to 3 independent sightings for them to investigate the car though. It was the case like that in VIC. But there they were too busy targetting imports and sending them to the EPA, rather than worrying about the old cars.
To be honest I don't see too many up here that meet that criteria, but there are a few rough ones around.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
