  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Just looked at the picture of the R34 25GT that was turbo'd in Greece....check out the advancement on the CAS!!! I can't get anywhere near that?
You guys reckon it's because he's got a T04E on the thing so doesn't get the quick on-boost pressure rise that I get? My one would ping it's nuts off there :P
Yeah he could've been real bastard bout it but he was really polite and as he said just doing is job, too bad we all yet again just hopped into our rides and took off like headless chooks, our hero leading the way to oblivion :)
And john we were telling you to come back, we were all right behind you as you sped off, but we went right there :) oh well did you get back and "open a can o whupp ass"? honstly I thought it was gonna be on when the shouting got louder and louder to and fro strutto...........I was scared :P
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
