  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
cyrus, if you have 1000 points how come we can't see them?
Cause everytime I hit 100 I deposit them into the bank :P
Anyway I am going home, mmMMmmMMmm nandos sounds good too bad they dont got a drive through, meh oh well :D
