So what ill need to do would be to change the Gtst resistor pack to the GTR one? or is dont gtst have a resistor pack as such?
thanks Roy much apreciatted!
Get your hands on an RB20DET wiring diagram, you will find that the wiring diagram for the R32 RB20DET and RB26DETT are on the same diagram (well they are on mine) which helps spot the differences.
The RB20DET does not have a resistor pack, the GTR does. Essentially you need to cut into the power wire that feeds all the injetors, off the firewall it runs on top of the fuel rail branching off where there are injectors. So before it branches off to feed a voltage to any injectors you need to cut it and solder it to the 7th wire on the resistor pack. Then from the resistor pack you have 6 wires that then run to the +ve spade on the injectors. So essentailly you are wiring the resistor pack in series before the injectors, just as std on a GTR.
I should have taken photos... :Oops:
  • Replies 121
Hi jnr32r, Power FC requires the standard impedance injectors, which on an R32 GTST RB20DET are 12-14 ohms (generally called high impedance). R32 GTR RB26DETT have low impedance injectors, around 3-5 ohms. If you use low impedance injectors then the PFC will get too much current drain and overheat.
Hope that helps
I am using 13B non turbo injectors which are either 420cc or 460cc Lol damn memory! Anyway I got them from a fella from nissansilvia.com for $35 each. They fit straight in, the last 4 digits are 1350 from memory??? Anyway I also, during the conversion got new injector plugs, which are similar to the stock ones except the lug is in the centre and not offset. They also have the spring you push down to unplug them vs the spring clip that gets flicked off and lost. I am running a microtech LTX12 (a 180sx RB20DET) and haven't got the car back yet so I cannot comment on the further.
do you happen to have pics of the mod'd clip to fit the 13b injectors? Thanks
Im not using a Power Fc but am using the GTR injectors & resistor pack on RB20 ECU.
So std RB20 ECU requires high impedence injectors to limit the current to the ecu...so can use:
- high impedence injectors and standard ECU OR
- low impedence with resistor pack, and std ECU. As impedence of (low impedence injector + resistor pack) equated to using high impedence injectors, the ECU doesnt know any better.
Hope that helps
Will that still happen even if you have a resistor pack, from RB26?
well, injectors are on way :D
Once I have got hold of the management side of things, they will be going in and then I guess we'll see how they work
Chris
  • 6 months later...
Hope that helps
I hope this is'nt true because I have a PFC and GTR injectors/resisters are going in this weekend
Thanks Champ. Don't kill yourself getting the work finished this weekend. I'm currently looking around for some injectors so i can be safe running higher boost => more power on the straights at PI and Sandown :P
I have'nt put them in yet coz I was finding out if they would work with the PFC.After reading SK post it put me off trying it coz I did'nt want to do damage to the ECU.
Roy you'll be the first to know how it goes after I finish that beer.
Chris32 I'll take pics as I go.Hopefully this weekend I'll do it all.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
