Need A Stock Exhaust Vic Guys, Help Me Out Epa!?
got a letter from EPA, looks like someone reckons my car is loud, but at 84 db limit i think all modified cars would be. anyways i need a stock exhaust for my car to pass any one have one that i could buy/borrow. need help ASAP. thanks
dave
0400552258
84? dunno just going by what the tester said, maybe i misunderstood. but he told me not to waster my money reckons it wont pass with the silincer anyways so go get a stock or give him $400 for tripple muffler setup????!!!!
did you wanna lend/sell the stock exaust alex?
Don't bother trying to pass with a modified exhaust, I thought mine was quiet...turned out to be 98db. The standard one is about 88db @ 5000rpm or something...the limit and the RPM it is tested at is nothing short of ridiculous. And the GTR as far as I know, breaks the limit in standard form. Chuck a stock one on just for the test if you want to risk it again, or get some ridiculous three muffler system for a permanent solution.
Just another example of our police force equipping servicemen with hearing abilities that would put Superman to shame. And YOU have to pay for the test :blink:
  • 3 weeks later...
Just another example of our police force equipping servicemen with hearing abilities that would put Superman to shame. And YOU have to pay for the test ;)
and no repercussions when they're actually wrong,
would you prefer a noise test on the spot? What if you fail then? Then there is no reason not to issue you a fine or say the car is undriveable from that moment.
At least with the current system, you can change it back to standard and then go to to noise test
Sure you get done for a $xx test fee but I believe its better than any possible on-the-spot fine if they do testing when they pull you over.
(this all based on cop issuing noise epa notice)
std r32 gtst exhaust is 89db so anything modified will be over the limit. Majority of skyline drivers would be over the limit unless they spent money on a custom silent exhaust.
yup, i dont really mind a fine on the spot, but then again, for an accurate noise test, there are a lot of requirements that have to be met... so. any reading that's taken by the side of the road, where there are trees and shit, can be disputed, no?
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
