need an electronic boost controller to stop boost spikes but i dont have much cash at the moment.
been looking on ebay and just wondering if anyone has tried these ones and what they thought???
http://cgi.ebay.com.au/JDM-Multi-Function-...=item2a08fd734d
https://www.sau.com.au/forums/topic/343510-boost-controllers/
If you are getting boost spikes with no boost controller it wont help, it is your gate setup that is causing it, boost controllers can only make the boost come on faster and higher, cant lower it or make it slower.
What are you currently using for boost control and what is your turbo setup?
Edited by Rolls
its just got a shitty turbosmart bleed valve. just running the stock N1 turbos.
fingers cross its just the bleed valve causing it. i really dont wanna go chasing problems.
starting to wish i kept the V8!!!
Get rid of the bleed valve and get an EBC, eboost street are around $400 and very good, as good as any of the other brand name ones for $600+
You could also try reducing the line size on the bleed valve, the mechanical ones often spike if they have more than 10cm of line on them, when I first got my first turbo car it had almost a metre of line, spiked to 16psi then dropped to 10 on the lowest setting with a turbo smart one, cut the lines right back and it got a lot better but still spiked.
EBC is the only way to go, a stock GTR controller should let you run 10psi quite easily and this is all you want to run max anyway if you dont have supporting mods, if you do then EBC it up.
hey sorry to take your thread but does any one know about an ebc that will have a high/low boost button.
ie. press the button remote mounted and your car goes to 20 psi until button if pressed again, then boost goes to 12psi.
not the turn and push because to have the car leagel in qld you cant have a in cabin ebc. may get around the boost controler in cabin senario by putting the controler in the bay or deep inside the dash and just hiding the solenoid. yeah sorry about the hijack but this may be used in future by me.
David
As Nismoid said get a turbotech boost controller so many people have used them with 0 issues (me included) they even do an electronic kit now for like $80. It's all on ebay not sure how their electronic kit works but if it's anything like the MBC it will be very good
David
pretty much all have different boost settings where you can just press a button, just cut the ass out of your ashtray and mount it in there, easy access and no one will ever see it, thats what I did
Benefit of Dual over single solenoid ?
Dual's tend to hold boost more reliably and tend to reduce any boost spikes caused by the EBC itself.
As they are Dual Solenoid they can meter/read from two sources therefore have a more reliable reading.
David
Turbosmart eboosts can have a remote mounted switch wired to earth that changes between boost groups.
Get a decent ebc man, your standard nismo turbos are good for 20psi mine are anyway. Im making 300kw on 18psi. Get the ebc and a PFC and send me a PM. I can get you good dyne time at a good price
David
gizzmo ebc allows a remote button to switch profiles or overboost for x no. of seconds
thanks will keep that in mind
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
