love seeing the little clouds appearing off the sides of the rear wings on the straights.
and we're off to a commercial break. just what we need while it's still wet..... and we missed schumachers radio message. oh great and we have to watch some stupid music shit.... not even ads for products, we have to watch lame promotion of another show
It makes perfect sense, just like Ferrari should do for Massa.
It's Webber's fault for f**king the start/first lap so bad
i know it makes sense. but they brought him in too early, which was sort of my point. but even if webber was in the lead they'd still bring him in as the test dummy
Yes and no...1 lap early maybe, considering he's setting the fastest lap now, and right in time considering Vettel would come in a lap or so after him, being the ideal time with the top 4 drivers pitting
who else thinks that redbull will pull webber in, put slicks on webbers car to see how they perform so they know when to put them on vettels car?
Well called. We've seen an early move to slicks work for Webber before too, don't forget
