Interesting, good to see an official explanation on it. Surprised it wasn't kers related
me to, i thought it was a battery fire/ explosion (having seen them explode it the past)
i didn't know that they have air power valves, does anybody know if they are air powered open and closed or if they use a cam to open the valves and then the air to close the valves?
Helmut Marko has revealed that Daniel Ricciardo will most "likely" replace Mark Webber at Red Bull - but it won't be next season.
With Webber on the verge of signing a new one-year contract with Red Bull Racing, Ricciardo, who made his F1 debut with HRT at the British GP, is set for another season with a lower ranked team.
However, the 22-year-old can look forward to a bright future with a Championship-winning outfit as Marko says he'll most likely take Webber's race-seat when the older of the two Aussies calls it quits.
"Mark Webber will stay with us for another year, and then he will decide what to do in his career," crash.net quoted Marko as having told the Italian media.
"Red Bull will decide who takes his place, although it is likely it will be Ricciardo."
yeah buddy
That's what alonso thought of hamilton back in '07, we'll just have to hope by then ricciardo can bring it to vettel. If he's aggressive, and he's a young aussie male so he probably is, he might be enough to push vettel out of his comfort zone.
hards are goooone ferrari must be happy
Having announced that they won't use the hard compounds in the next three races, Pirelli have now confirmed that they are dropping the tyre completely.
Pirelli announced after the Hungarian GP the compounds for the next three races with the medium and soft compounds being used at Spa and Monza and the soft and super softs at Singapore.
The Italian tyre manufacturer's decision raised some eyebrows as it is well known that Ferrari especially struggle to get heat into the hard tyres.
Pirelli, though, were quick to deny favouring the Italian stable but may have to issue another rebuttal after Paul Hembrey confirmed that the hard compound would not be used again this season.
"I don't think we'll see the hard compound again," Pirelli's motorsport boss told Autosport.
"I think it's probably too hard and that the medium is proving sufficiently robust for the aggressive circuits we've still got to come. So don't think we'll be going the hard route."
He added: "Probably next season the medium will become the hard. We'll probably slot something in between the current softs and mediums - We want to keep about one second between each.
"The super soft and soft gap is about right to be honest, because you've got a 1s speed advantage but you've got a clear degradation and limitation on use.
"If we could replicate that now with a new medium and a new hard then I think we'll be well placed."
pf1
Hey guys meed some help
Missus is getting me a 4 corner pass for melb 2012,
But the brabham stand (the most exxy package) is where id b sunday, but it doesnt look to be a fantastic spot?
I
Was in piquet stand last yr, (crn 4) and was nice and slow so u could see them.
Where are all u guys sitting and have sat b4? Any tips?
And where did u get ur pit walks from??
brabham is a good stand. inside of T1 so you're almost guaranteed a first lap first corner acco. plus that's usually a good passing spot up the inside of T1, hold it on the outside through T2 then hold that line for the inside of T3 and job done.
yeah the cars come in hot down the straight but T1/T2 is a fairly slow chicane type of thing. you will see plenty.
sounds like a plan!
just fox tickets yeh? ill harass them for the pit walk. hopfully ill get in! did u get an extra ticket for that or anything?? and is it on sunday the pit walk?
thanx guys :)
saw shuey have a fairly quick gravel slide last yr in piquet. good times! should organise to catch up as a group and go for a sniff around the place, plenty to 'see'
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
