q&a with mark webber here
pf1
Revised Grid
01. Sebastian Vettel Red Bull-Renault
02. Lewis Hamilton McLaren-Mercedes
03. Mark Webber Red Bull-Renault
04. Felipe Massa Ferrari
05. Nico Rosberg Mercedes
06. Jaime Alguersuari Toro Rosso-Ferrari
07. Bruno Senna Renault
08. Fernando Alonso Ferrari
09. Sergio Perez Sauber-Ferrari
10. Vitaly Petrov Renault
11. Sebastien Buemi Toro Rosso-Ferrari
12. Kamui Kobayashi Sauber-Ferrari
13. Jenson Button McLaren-Mercedes
14. Rubens Barrichello Williams-Cosworth
15. Adrian Sutil Force India-Mercedes
16. Heikki Kovalainen Lotus-Renault
17. Paul di Resta Force India-Mercedes
18. Jarno Trulli Lotus-Renault
19. Timo Glock Virgin-Cosworth
20. Jerome D'Ambrosio Virgin-Cosworth
21. Pastor Maldonado Williams-Cosworth
22. Tonio Liuzzi HRT-Cosworth
23. Daniel Ricciardo HRT-Cosworth
24. Michael Schumacher Mercedes
there's a good opportunity here for young daniel to get behind schumi and learn from the best. :)
far out tarmac run offs are gay! There should be consiquences for going off the track
Nando was almost tarmac rally spec with 2 wheels in the grass on the inside of the corner
Edited by sav man
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
