vettel's off the hook.
statement from the FIA read: "Having heard from the driver and team manager, and having noted that Car 1 started what was its fastest qualifying lap with 17 seconds to spare prior to the chequered flag, the stewards determined that no advantage was gained when car 1 left the track.
"Accordingly no breach of Article 20.13 occurred on this occasion and the stewards decide to take no further action."
Edited by tweety bird
I think more so because LH won't be able to look after his tyres given the way he sets the car up. His best hope is to get a very sizable gap off the start and hope McLaren can find a nice big hole to drop him in (and hopefully away from Massa).
If he can control himself for 2hrs he might get away with the race.
due to his ability to look after tyres?
yes, but more of that i don't think the rest will look after there tyres.
it's going to be a race about tyres, redbulls are hard on there tyres so are the ferraris, mercedes will be strong here but are unlikely to pose a threat and hamilton well.....
you know what im going to say. :)
I predict Ham will just drive away from the field in the opening stage of the race.
Jenson will pass Vettel and stay P2.
Seb will be on the third step of the podium and inconsolable.
    • A bit late but A disk S13P fit over stock R32 GTR brakes, usually A disk front, O disk rear works.
    • Or, the height of the release bearing is not correct for your combo. Start with the bleeding and checking the slave moves throughout its range when you press the pedal (2 person required), but it is possible for the height to be internally wrong too (box back off to measure.
    • Yes, there's quite a few things that can go wrong during a clutch install. Very unlikely. I have a similar clutch. They (ACS) make good gear. No, it is not normal. It is possible that you just need to bleed the clutch slave. But the new clutch will also have a more aggressive actuation force/pressure, and so your old slave cylinder might be a bit leaky or otherwise compromised, and not up to the extra force required. Or the master cylinder, same.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
