Check the knock sensor loom for any splits / continuity and so forth and make sure that it is getting a proper signal from the knock sensor.
use temp IGN adjust to back out -8 deg timing and floor it
if its does the same you can be pretty sure its not ignition related knock and some form of mechanical noise etc
yeh i have tried this its better but still manages to hit 70 very easy...
hey trent i have this "false knock" issue im trying to sort out perhaps you have some ideas...
i have a rb25 with a power FC making 200kw, basically i get crazy knock readings and i'd really like to fix it so i can have a go at tuning the car.
on startup it will read 20-40 and i can be driving along in any gear around 3000-4000rpm not much load and it will shoot up to 80-100. On WOT it can hit 200.
I have had 2 different tuners check the car out and they reckon its fine, its been in this state of tune for over 20000ks with no issues.
I have a 5 puk exceedy clutch, oil cooler and relocation kit, other than than that its pretty standard. I have tried changed the knock sensors but there was no change.
whats the best way to eliminate this problem??
Some PFC's have this issue we come across it every so often, its generally a knock sensor issue or a loom issue...
One of the reasons we like to use secondary knock detection when tuning.
how long does it take to setup a kmon or similar for the 1st time? do you have to set it up for each engine and car?
2mins max, on big setups maybe 5mins as i prefer to get to a better spot on the block instead of the head.
Ive got an rb30 turbo with a really quiet exhaust. The car seems to drive perfectly, run really smoothly. Are you saying It could just pre ignite at any time or be detonating and i wouldnt even hear it? I thought pre ignition sounded like a marble or something in your cylinder, like a really pronounced bang?
Also what is the optimal spark plug to run in it. Its a standard N/a motor, high comp, n/a cam etc, with vlt injectors, vlt computer, stock manifold turbo etc. Will be installing water injection soon and trying to push it to 14psi. From what ive read if i get the water right i can lean it out a bit even on the n/a high comp motor. Only problem with doing that is if the water fails then almost certainly your motor will too. Its been going for 2000km and the sparkplugs have no signs of wear, this is a good sign of no detonation right?
And in your opinion how much longer (i,e a few seconds?) can forgies handle pre ignition for versus cast pistons?
Kind regards,
Jason.
Bad detonation sounds like marbles but by then it is too late, you can still get detonation that you won't hear unless you've got your head in the engine bay.
Pre ignition is a different thing that can destroy a piston with just one event. It is where it ignites on the compression stroke, basically trys to compress an explosion. Detonation is where after the spark ignites the fuel the shock wave causes some of the mixture to explode instead of burn, so there are different stages, can have a very small amount of the mixture explode or almost all of it.
Pre ignition will destroy any setup, detonation will be better tolerated by forged pistons but as its such a variable thing there is no way to say how long it'll last, avoid it at all costs.
Edited by Rolls
Kind regards,
Jason.
detonation is very distinct if you know what it sounds like. i'd never heard it until it was pointed out to me one day, and now i pick it up all the time, even just on normal cars driving in traffic that *should* be run on a decent fuel but are only getting fed 91oct.
spark plugs generally wont cop any damage from detonation, but will show some black specs, or even silver ones, around the porcelain.
hard to put a time constraint on how long each piston would last for. i've been caning a mates soarer recently while chasing what i thought was ignition braking down, which was actually a massive lean condition, despite being told by a dyno operator that it was flat at 11.5:1 (issue currently being rectified with help from trent), and its been copping it hard, and for a long time lol. still going strong though, standard cast pistons :)
instead of spending your money on water injection, get some GTR injectors and a nistune. cost a little more but the result will be about 487 times better
haha those gas love that 11.5AFR dont they.... shit it was more like 16 to 1.... was lucky we checked their work.
leaning out an engine can be tolerated for a lot longer, especially if its waaay too lean. as long as it doesnt create hot spots such as glowing spark plugs that cause preignition
Engine Vids with knock sound on Youtube:
http://www.youtube.c...feature=related
Kabbom:
That was in the back the motor is in the front, so i dont think that this is det. lol.
The first vid was good the sound that det makes mate.
  • 1 month later...
Rb 26 is impossible to mount onto the block. So have to mount to the engine head preferably near a coolant passage as the knock will travel through the water better than air.
Yavuz prefers to use his trained ears to listen for knock
Nope. And that proves it works fine.
He has a extremely good reputation.
The drag car he sponsors is tuned at the track using egt sensors and transducers in the spark plug to monitor cylinder pressures.
    • I mean, I got two VASS engineers to refuse to cert my own coilovers stating those very laws. Appendix B makes it pretty clear what it considers 'Variable Suspension' to be. In my lived experience they can't certify something that isn't actually in the list as something that requires certification. In the VASS engineering checklist they have to complete (LS3/NCOP11) and sign on there is nothing there. All the references inside NCOP11 state that if it's variable by the driver that height needs to maintain 100mm while the car is in motion. It states the car is lowered lowering blocks and other types of things are acceptable. Dialling out a shock is about as 'user adjustable' as changing any other suspension component lol. I wanted to have it signed off to dissuade HWP and RWC testers to state the suspension is legal to avoid having this discussion with them. The real problem is that Police and RWC/Pink/Blue slip people will say it needs engineering, and the engineers will state it doesn't need engineering. It is hugely irritating when aforementioned people get all "i know the rules mate feck off" when they don't, and the actual engineers are pleasant as all hell and do know the rules. Cars failing RWC for things that aren't listed in the RWC requirements is another thing here entirely!
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
    • The hydrocarbon component of E10 can be shittier, and is in fact, shittier, than that used in normal 91RON fuel. That's because the octane boost provided by the ethanol allows them to use stuff that doesn't make the grade without the help. The 1c/L saving typically available on E10 is going to be massively overridden by the increased consumption caused by the ethanol and the crappier HC (ie the HCs will be less dense, meaning that there will definitely be less energy per unit volume than for more dense HCs). That is one of the reasons why P98 will return better fuel consumption than 91 does, even with the ignition timing completely fixed. There is more energy per unit volume because the HCs used in 98 are higher density than in the lawnmower fuel.
    • No, I'd suggest that that is the checklist for pneumatic/hydraulic adjustable systems. I would say, based on my years of reading and complying with Australian Standards and similar regulations, that the narrow interpretation of Clause 3.2 b would be the preferred/expected/intended one, by the author, and those using the standard. Wishful thinking need not apply.
    • Yes they do. For some maybe. But for those used the most by abusers, ie Skylines, the numbers are known. The stock eyebrow height for R32/3 Skylines is about 365/375mm or thereabouts. The minimum such heights are recorded in adjacent columns in the database.
