Maybe i do, ill try clarify.
Is there a difference between boost pressure and wastegate pressure? I always thought that wastegate pressure was a result of boost pressure?
What exactly is turbosmarts eboost2 claiming in this video?
Thanks for your patience.
they are saying it controls when the solenoid allows boost to get to the wastegate (solenoid closed = no pressure getting to the wastegate which should give reduced wastegate creep before full boost so boost builds as fast/hard as it can, if you lower it boost should build a little slower/smoother)
right right, so a typical boost controller has no solenoid to stop pressure to the gate?
Boost controllers like the Blitz SBC are dual solenoid but they dont offer functions like gate pressure. The 2 solenoids are purely used to get a more accurate boost reading from 2 points, no?
Seems like this Eboost stuff is a step above the JDM stuff.
All boost controllers, whether manual or Electronic control gate pressure, by bleeding off pressure before it gets to the gate actuator, E-boost is no different.
+1 that seems to be what he's after
once a set boost pressure is reached, a diaphragm in the actuator moves to open the wastegate, boost controllers work by bleeding pressure away from the actuator so the wastegate stays closed, building more boost until the pre-set boost controller allows the actuator to open.
Not an exact, point perfect description but hope it makes sense to the OP.
Blitz use dual solenoids to quicken response and control (as it has double the resolution)
Blitz call the their version of turbosmarts gate pressure control "gain" so look for any controller that has gain functionality. Greddy call it "set boost"
What do you mean function? They both function in exactly the same way… and that is…
1. They ALL control the pressure via the wastegate.
2. They do this via the solenoid/stepper motor.
3. Dual solenoid just adds an additional element of control (I wont go into details about how “much” better single vs dual, plenty of threads on that)
So simply put - There is no way around this when using a EBC & external gate.
The eboost stuff is not specifically better than say… a HKS EVC6
You are getting confused with what they are calling “gain” as Trent has said. Its nothing more than one company marketing it as something else.
If it were me, I’d be using a EVC6 (which I will be doing shortly :bunny:)
Right right, if i may put out another question then.
Why do people run higher wastegate springs in their external gate when they can automatically control the pressure via boost controller? Why dosnt everyone run a 7psi spring compared to a 21psi spring?
When u say better boost control, what exactly do you mean? Having a higher boost spring would bring up issues like boost creep/spike wouldnt it?
Could people clarify how a cars response would be affected on the following setups
wastegate spring of 15psi, Peak boost of 20psi
wastegate spring of 10psi, peak boost of 20psi
both controlled via ebc.
Thanks for all your time guys.
Edited by Jap_Muscle
base wastegate spring of 10psi will generally taper down a few psi @ 20psi (say 3-4psi)
base wastegate spring of 15psi will generally taper down a few psi @ 20psi (say 1-2psi)
It is best to run a spring closer to your set pressure.
TTheory often doesnt always relate to real world results..... as manifold design turbo design, gate position etc all contribute.
but if you stick to one rule (It is best to run a spring closer to your set pressure.) you will generally be @ a good starting point.
You get gate creep from having TOO WEAK of a base spring rate, not too high.
10psi spring running 20psi is more likely to get gate creep
than
18psi spring running 20psi
Gate creep = gate creeping open before desired boost level. Most commonly attributed to weak gate spring rate.
www.hotstuffworks.com - Go have a search mate. Great site that explains the basic stuff.
No wonder you have issues with your setup currently, sounds like your tuner/building is feeding you rubbish :bunny:
EDIT: Trent beat me, damn using my mobile lol
You can control boost with just the wastegate e.g. RB20 with a single line to the actuator or an adjustable wastegate like the Synapse. The correct wastegate properly installed will not spike or creep. A boost controller (any one) is just delaying the action of the watsegate by bleeding off the pressure to the wastegate. Response can be varied a little bit by a boost controller which will delay the opening of the wastegate but ideally the wastegate will be doing most of the work and the boost controller is just a "trimmer".
[edit] better put by Trent
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
