I was thinking of getting the same configuration as this:
http://www.skylinesa...ttach_id=303024
Do you think this would be affective? Not sure exactly how it's hooked up, but there seems to be only 3 hoses (1 going to the cam cover, one to the intake pipe and one to the dipstick sump? Not entirely sure. Bit hard to tell in that photo.
looks a bit like it may have a primary/secondary can setup... More than likely having the inlet side can returning to the rear turbo oil return. If the Primary can is returning to the dipstick it should be a good setup.
I also like the Autech catch tank with a nismo catch can....this is the best setup...like the Gibson gtr..Just make sure you use the std cam baffles or modify the Mines baffles so the oil can drain back into the head from the Autech catch tank.
What I have found however if you have too much oil in the head no catch can will work. Sort that out first.
Edited by BoostdR
im on the process of setting up my catch can,
i was wondering if its safe to run the oil back to the sump due to condensation???
I wouldn't run it back to the sump... On various times I have found substantial amounts of water in my catch cans!
It's not really that hard to top up the motor with oil every once in a while if it is breathing :)
my oil dip stick keeps popping out with this set up, does any one know why ?
Under boost, the PCV valve closes, and the rocker covers have nowhere to vent at all... The pressure pushes down into the sump and pops your dipstick out as the only way out.
That's my engine bay! lol. I have found that it works well. I used to get some oil in the catch can from sustained high rpm/boost when I didn't have the catch can, and that would coat the intake side with oil. No more draining catch can now that it drains to sump. Now that I plumbed it into the dipstick hole, it's great.
There is no secondary catch can, the PCV is still setup as per factory, as I did a fair bit of testing in the past and found that the majority of oil comes out of the LH breather (closest to turbos) so I left the other one alone.
One of the guys on here didn't have a catch can and he had dramas with oil usage (read oil going into intake and intercooler). A standard car would get away with it, but a modified engine with more boost will push that oil out. We would do an oil change and wonder where 2.5 to 3 litres of the original 6 went!! I organised a catch can for him as I got sick of cleaning AFM's too :)
What do people think about this setup?
Blocking the standard PCV line, then a single host from the exhaust-side rocker cover to the catch can and then back to the turbo inlet?
Less messy hoses in the engine bay, and no oil vapour directly being allowed into the intake manifold.
Thoughts?
  • 8 months later...
I've had my catch can on now for several months now and havent noticed a single drop being collected in the catch can
Here is my current catch can setup:
As pointed out in the photo, I've noticed there's a little pool of oil building up in the catch can hose. So I'm guessing it's not getting enough vacuum for the oil to reach the can?
The drain plug on the catch can is still capped off and not a single drop of oil has come out when I open it.
This is pretty much the same setup as GTRsean's, minus the can draining to the dip stick.
Does anyone have any other recommendations or setups? or should I just keep sticking to this? I haven't done any modifications to the PVC/plenum side (if there's any to do?)
i have an arc catch can, pcv blocked off with grub screw, exhaust side outlet to turbo blocked as well as rear turbo one, and single hose going from intake cam cover to the baffled catch can
Edited by BWRGTR
Hey Owen,
I just changed to the nismo setup as I was having oil into the intake issues. You will need to put a restrictor in the line that goes into the rear turbo inlet pipe, I didn't do that silly me. The stock rubber pipe had one in it(cam cover outlet to rear turbo inlet pipe). It draws a lot of vacuum on boost!
Hey Owen,
Can you show me some pics of your setup?
Howcome you put a restrictor in? Wouldnt more vacuume be better to suck the gasses out of the cam cover?
I removed my catch can because it never had oil in it after a year, and when performing an intake pressure test, the catch can was a leak in my intake (the level reader thing). No oil in my intake so at least I know my engine isn't spluttering oil all over the head.
    • The rain is the best time to push to the edge of the grip limit. Water lubrication reduces the consumption of rubber without reducing the fun. I take pleasure in driving around the outside of numpties in Audis, WRXs, BRZs, etc, because they get all worried in the wet. They warm up faster than the engine oil does.
    • When they're dead cold, and in the wet, they're not very fun. RE003 are alright, they do harden very quickly and turn into literally $50 Pace tyres.
    • Yeah, I thought that Reedy's video was quite good because he compared old and new (as in, well used and quite new) AD09s, with what is generally considered to be the fast Yokohama in this category (ie, sporty road/track tyres) and a tyre that people might be able to use to extend the comparo out into the space of more expensive European tyres, being the Cup 2. No-one would ever agree that the Cup 2 is a poor tyre - many would suggest that it is close to the very top of the category. And, for them all to come out so close to each other, and for the cheaper tyre in the test to do so well against the others, in some cases being even faster, shows that (good, non-linglong) tyres are reaching a plateau in terms of how good they can get, and they're all sitting on that same plateau. Anyway, on the AD08R, AD09, RS4 that I've had on the car in recent years, I've never had a problem in the cold and wet. SA gets down to 0-10°C in winter. Not so often, but it was only 4°C when I got in the car this morning. Once the tyres are warm (ie, after about 2km), you can start to lay into them. I've never aquaplaned or suffered serious off-corner understeer or anything like that in the wet, that I would not have expected to happen with a more normal tyre. I had some RE003s, and they were shit in the dry, shit in the wet, shit everywhere. I would rate the RS4 and AD0x as being more trustworthy in the wet, once the rubber is warm. Bridgestone should be ashamed of the RE003.
    • This is why I gave the disclaimer about how I drive in the wet which I feel is pretty important. I have heard people think RS4's are horrible in the rain, but I have this feeling they must be driving (or attempting to drive) anywhere close to the grip limit. I legitimately drive at the speed limit/below speed the limit 100% of the time in the rain. More than happy to just commute along at 50kmh behind a train of cars in 5th gear etc. I do agree with you with regards to the temp and the 'quality' of the tyre Dose. Most UHP tyres aren't even up to temperature on the road anyway, even when going mad initial D canyon carving. It would be interesting to see a not-up-to-temp UHP tyre compared against a mere... normal...HP tyre at these temperatures. I don't think you're (or me in this case) is actually picking up grip with an RS4/AD09 on the road relative to something like a RE003 because the RS4/AD09 is not up to temp and the RE003 is closer to it's optimal operating window.
    • Either the bearing has been installed backwards OR the gearbox input shaft bearing is loosey goosey.   When in doubt, just put in a Samsonas in.
