Hi. To whom may concern......
I'm a custom of gumtree that bought a nissan skyline R33 1995 s1 with a s2 front end body from a Barbara and Bobby that was false ID and fraud people that pinch people cash...have no consideration that I bought the car from them for my son that has an illness of short time life. The number plate is ZR.38.AM, colour of vehicle is yellow. They also had Ebay financial agent working with them name Alexander Wade at 215 little collins street Melbourne vic 3000 AUSTRALIA. Also Barbara & Bobby address is 23 Charles street, Cooktown 4871 QLD AUSTRALIA.. Custom paid money for the car at post office and the workers sent it to western union money transfer.. To everyone out their to not trust internet unless u truly know them from your heart because I've been scammed big time.so plz.. if you see this car plz call or text me on 0401717703 thanks to all take will help
For the love of god! Boy, how stupid are you. I mean seriously, I take more precautions buying a t-shirt online FFFFFFFFFUUUUUUUUU
  • 1 month later...
haha I had a mate of mine have someone try this in reverse on carsales (was total bullshit to start with, offered him the inflated value he had on his R33, was going to buy it sight unseen but needed him to send $500 for the supposed buyer to organise shipping LOL)
OP: maybe you should stick to buying cars in person lol
^^^ thanks Brian, I'll have a read tomorrow. Ta. :D
http://www.zug.com/pranks/powerbook/
i think this is the best one in the history of the internet Terry. Promise me you will read this.
I lost my shit multiple times at work reading this. Must've looked quite the twat rofl
I have been trying to remember what that was called for yonk
Cheers :D
I honestly want to know how you managed to even get the money to buy a car for your poor dying son? I guess banks will lend anyone money these days. to be honest though I'm struggling to sort the truth from the nonsense in your posts. if you really did get scammed then get serious. give us the details, how much? who to? when? etc and maybe someone can help you.
Thanks for that Troy > had to laugh at various points like...
* Trader rating on e-bay had they processed the deal there
* Obtaining the address etc etc.
So well played at each stage. :rofl:
  • 6 months later...
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
