Do you still have your standard Stagea seats? Build/acquire a frame to put around it and that would make a pretty sweet set up IMO. :P
I do, Mr Cass. Are you handy with a welder?
Also, I need somewhere to store it.
  • Replies 201
Posted Images
I have a welder at home, but I'm am pretty shithouse at welding...
However... working in a factory with MIG and TIG welders as well as people that are paid to use them may have its benefits :P
mmmm GT5 :) its slowly taking over my time I spend on blackops :D
aghhhh 2 new games = no "out of living room" life atm >.<
still haven't seen a stag yet.. just got 250k from special events.. gonna have to spend it on a Ferrari :)
good game = fun.
havent worked out how to put different tyres on front/back
going to need to setup a wheel at some stage, controller stick is too hard for some of the special stage events
^^ just before u start the race there is an options tab there u change to different tyres front and back there pending ur car has them..
Stag definatly need hard on the back to stop the understeer
I have googled the stigs lap times and been running cars round the top gear track to compare..
Edited by matty_M35
Yea I have a 260rs on GT5 with just over 450hp drive pretty well but as soon as you take traction control and stability control off it can be a bit of a handfull out of the corners when you plant your foot
http://hyperdrive.cart.net.au/store/hyperdrive/
just get one of these.....there cheap.....and then remount a decent seat to it.....works a treat!
If I can find something similar to that which can also be folded up for storage, then that would be awesome. I'm pretty sure there are some out there that do, it's just a matter of looking for and finding one.
soft :down:
anyone who uses traction and/or stability control isnt really driving the car.
tell me how good assasins creed is mate, im getting it for xmas
Iain, started playing it today, it's pretty damned good! Some new features here and there, but I'm still in the early stages.
Picked up a black 260RS the other night, haven't driven it yet.
Likewise, then took it for an oil change and a quick spin.
Man, what a slug... sorta expected when compared to the Tommy Kaira ZZ-2 though :P
Finnally got my car, a black 260RS. Havent had time to drive it yet. Looking forward to having some fun playing with the torque controller thingy and sending the power to the rear after fully working it!!
I'm slowly getting thru GT5 when i get spare time.
A-spec beginner and amatuer races all done, half way thru professional
B-spec beginner races all done
I finally got a stagea in used cars, and painted it Bayside blue FTW! now it matches my R34GTR Vspec with 800hp
and me Ae86 Panda
Sucks that you can't change wheels on a non-premium car though :down:
I really hope they fix that eventually, its stupid. And they need more aero parts on a lot of the cars too. I dont want it to turn into Need For Speed type crap, but some more options would be nice.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
