Ok
Here is a current list of SAU 3.0 issues outstanding.
Please advise if you know of anything that has been missed.
- Signature/Profile sizes not being “scaled” correctly:
Eg below. You can see the large pic goes under.
Profile: http://www.skylinesaustralia.com/forums/user/42272-don-dada/
- Forum Clock is out by 1hr. Posts made @ 5pm, say 4pm.
- Trader rating viewable from threads
- SA Club user bars (Exec are fine, Club are not working)
- Remove reputation system
- “Report Post” button does not work, spits out error
- 10 post restriction before PM, has been removed. Needs to be reinstated. Already had spammers attacking the forum.
Thanks
https://www.sau.com.au/forums/topic/346495-sau-30/page/19/#findComment-5622785
Ok
- Signature/Profile sizes not being "scaled" correctly:
Profile: http://www.skylinesa...42272-don-dada/
- "Report Post" button does not work, spits out error
Thanks
Sweet - will start attacking that list this arvo.
Thanks Ash.
https://www.sau.com.au/forums/topic/346495-sau-30/page/19/#findComment-5622819
Hey guys, not sure if this is the right place for this stuff
Not sure what's happened to trader ratings?
Also the iPhone version doesn't have an option for clicking on the page number. Would be good to see the page number listed as well as a 'go to page: ' form. Not sure if this is do-able or not, but thought I'd mention it.
Edited by mosquitocoils
https://www.sau.com.au/forums/topic/346495-sau-30/page/19/#findComment-5625689
Ash how come we're loosing the reputation system the negative's can be taken off so if you disagree you cant mass negative rep someone
It's already been abused in various sections of the forum.
Sadly, people cannot use the feature with any measure of maturity.
If we keep it, all its going to do is make work for Admin's having to reply to people that complain they are being rated down if they ask a silly question or whatever.
https://www.sau.com.au/forums/topic/346495-sau-30/page/19/#findComment-5626118
Well here is a suggestion for the rep system so people don't bitch and complain about having -200 rep *cough Doogle cough*.
Keep the system but don't let it go below zero if people get a negative. So you can only have positive rep (which people can't really abuse). A negative will still bring your rep down but won't allow it to go below zero. So wankers will just constantly have zero.
Thoughts?
  • Like 1
https://www.sau.com.au/forums/topic/346495-sau-30/page/19/#findComment-5626169
hey Guys
just went to report a dodgy post but the report script failed (couldn't determine type of content being reperted)
post is at http://www.skylinesaustralia.com/forums/topic/350625-buy-triamterene/
Cheers
https://www.sau.com.au/forums/topic/346495-sau-30/page/19/#findComment-5629616
ok one issues that i haven't seen fixed is
when getting a new conversation in my inbox i click the link and go to the conversation all good :D but it doesn't clear the icon of having a new message/conversation awaiting icon
https://www.sau.com.au/forums/topic/346495-sau-30/page/19/#findComment-5636721
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
